Has anyone used a cable plow?
/ Has anyone used a cable plow? #1
ccsial
NorthWest Illinois
(Kuboto L3400) (Ford 1900 4WD w/FEL) (Deere X748SE) All bought new
I want to lay about 1/4 mile of electrical cable, about #6, 3 conductor, from my shop to my cabin. The soil is pretty sandy. Has anyone used a 3PH cable plow? I didn't find anything but big rigs when I searched the web.
/ Has anyone used a cable plow? #2
There's a ton of threads on this subject here on TBN. But I believe they're in "attachments" or "build it yourself" forums.
Most areas have subcontractors installing cable and telephone drops. Unless it's something you just want to do I'd suggest locating one of these guys and working a deal on them plowing in your line. Their plows use a vibrating shear which allows them to go deeper easier then brute power will do.
/ Has anyone used a cable plow? #3
Like harv suggested, this might be one to sub out. For 110v you need to be deep enough for code and that will be tough unless you have the right equipment. The right 3ph equipment will be VERY expensive. An option might be to rent a chain trencher. It'll take longer but you'll be able to do it yourself if that's important to you. Good luck and let us all know how you make out /forums/images/graemlins/smile.gif
I kind of thought I'd be hearing this advice. I'll check around and see if someone can do it. My soil is real sandy so I was thinking I don't need the vibrating type. The trenching sounds like too big of a mess. Maybe someone rents cable plows but I doubt it.
I don't know what the code is but I was planning on stepping up and down to run 440 on the line in order to minimize voltage drop.
/ Has anyone used a cable plow? #5
You can also rent a vibratory plow and do it yourself. They are not difficult at all to run and shouldn't cost you all that much. Not sure if the rental shops in your area rent them or not but ours here rent the Vermeer (excellent machine) for about $250 day. I doubt you can get a sub to do it for less than that but maybe you would be able to.
Curtis
I'm going to check rental places later today and see what I can find. I called the two companies in the phone book under cable and both gave me an estimate North of $6000.00 less cable. That's dang near half a tractor. If nothing else, I'll rent a trencher and deal with the mess.
/ Has anyone used a cable plow? #7
ccsial,
I trenched 1/4 mile for my drop to the transformer at my house. Mine was a mix of soils including clay and stones, and trenched at 48 inches. We also layed the conduit ourselves. The trencher was a big 6" Vemeer, and worked great. Even backfilled with it. If I were you, I'd do the same since you could go shallower. The conduit would be a small investment now. If you have sandy soild you could have it all installed within a day.
I found a rental place that has a trencher for $139/day and a plow for $359/day.
I'll drive to the city Saturday and look at them and decide which one to use. I'm leaning towards the plow if it looks like it would do the job. I have to lay the cable out first since there is no reel on it. My only concern with the plow would be damaging the cable.
Thanks to all for the suggestions.
/ Has anyone used a cable plow? #9
</font><font color="blue" class="small">( My only concern with the plow would be damaging the cable. )</font>
If you are using the correct type of cable, that is, rated for direct burial, it is pretty tough stuff as far as the cable jacket.
/ Has anyone used a cable plow? #10
I needed to run a 110V line to the outdoor sign, my sprinkler installer pulled a pvc pipe for me with his slitter and I ran the wires right thru it, easy as pie. Since it's so late in the season, maybe a sprinkler installer in your area would put in the conduit cheaply for you?
/ Has anyone used a cable plow? #11
The spirnkler guys may not have a big enough machine to go deep enough. I think code is 24"? most sprinkler stuff is put in at 12" or 18" max.
Last I checked on rentals near me here in MN, I found a combo 24" vibe-plow / 36" trencher unit, Vermeer, I think, for about $350 per day. You get the best of both machines in one unit.
- Rick
2016 Ram 2500 6.4L HEMI (A62679)
2016 Ram 2500 6.4L...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
SKID STEER VIBRATORY ROLLER (A62613)
SKID STEER...
Stout Brush Grapple 66-9 (A66285)
Stout Brush...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
2021 CATERPILLAR 279D3 LOADER (A64553)
2021 CATERPILLAR...
