Has anyone converted a full size backhoe to a quick attach bucket?
   / Has anyone converted a full size backhoe to a quick attach bucket? #11
I have a 420 ford industrial backhoe, and I thought about putting a quick change for the bucket to forks or whatever, I changed my mind and just put 3 hooks,(similar to the 4 hooks on your bucket), and use a 1and 1/2 inch steel bar across the top and hung the forks on that, it hooks up quicker than a quick attach as I don't have to get off tractor to hook it up. the down side is I cant see the forks most of the time. they do hang down about 4 inches below the bottom of the bucket, but still cant see them if there on the ground, In any case they are very handy, just yester day neighbor had me load shingles on his roof, so his son didn't have to carry them up a ladder. We are both in our 70s so don't like ladders anyway.
the grapple part , I have a Hyd thumb on the hoe and use it all the time .
Hope this gives you some ideas , Have fun, Stay safe.
Rich
I have had that same fork arrangement for the past 30 years.
Exceptionally handy to use, and I use the forks WAY more often than just the bucket.
The problem is: The forks (mine are from an old Clark lift) are heavy, and in front of the bucket, so lift capability is cut way down.
I could lift much more with my set of real Ford forks, but that would mean manually swapping with the bucket.
That ain't gonna happen,
Those Ford forks are somewhere in the barn, under a whole bunch of other stuff.
I could always do that, but visibility and lift capacity is cut way down and I loose the ability of using other implements. The backhoe loader isn’t a wimp to begin with with 6500 pound full height lift and 8500 bucket lip breakout force but I’d hate to cut it in half with lousy forks. I was really thinking about cutting the back of the bucket out, welding some ears on that plate for the 4 point QA and having the metal fab shop make a new piece for the back of the bucket. I’ll see what they say about that idea. Making a new back plate might be challenging since their roller can’t handle steel that heavy.
   / Has anyone converted a full size backhoe to a quick attach bucket? #13
Doesn't anybody sell QA for excavators in the US for a reasonable price? Here in Scandinavian a lot of manufactors make quite cheap QA, the S type is very common and they make on order custom weldparts for buckets and machine.
I’m wanting an adapter for the front end loader, not the backhoe boom. The pin backhoe buckets change pretty fast and I currently only own one bucket. It’s a rare site to see a backhoe or excavator doing anything except digging with a bucket or rock hammering. The rock hammers are usually on dedicated machines. I’ve seen tons of excavator attachments from other countries but we don’t have those here for the most part.
   / Has anyone converted a full size backhoe to a quick attach bucket? #15
Oh, at the front :)
   / Has anyone converted a full size backhoe to a quick attach bucket? #16
I have a 310J but a $3000 adapter that’s only half the battle is out of the budget.
   / Has anyone converted a full size backhoe to a quick attach bucket? #18
I wouldn’t think the SSQA would be strong enough for the backhoe. Don’t they make quick attach setups for big loaders? Could you find one of those and fab up your own version? A lot of those machines have the center cylinder too.
Yes the big loaders sometimes have QA. It’s a 4 pin system. It’s nearly identical to the Kubota backhoe subframe mounts except upside down.
   / Has anyone converted a full size backhoe to a quick attach bucket? #20
This is something I’ve been wanting for a few years also. I called around for some quotes and I’m still in shock. I have a NH 545D with 5000lbs of lift to full height and a Ford 4500 TLB. The bucket forks are nice when you need them but they are clumsy and the bucket cheats you out of lift capacity.
I was looking at grapples also. EA told me a couple years ago they didn’t feel their grapple would handle the abuse an 11,000 pound utility machine could do to it. I really didn’t want to make everything but loader forks, grapple and the QA are all on the winter list.
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2002 WESTERN STAR 4900 EX TANDEM AXLE SLEEPER TRUCK (A58017)
2002 WESTERN STAR...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
2021 CATERPILLAR 306 CR EXCAVATOR (A52709)
2021 CATERPILLAR...
