4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 19,077
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
Who ever did it , doesn't want to talk about it,
because it broke in a swift and terrible way.
All the OEM's sell their own version of QA, these are a lot more HD than the skidsteer QA system. Be prepared for sticker shock if you want to buy the parts. You might get a better deal finding and buying a machine with QA and attachments already and selling your old machine.
I have had that same fork arrangement for the past 30 years.I have a 420 ford industrial backhoe, and I thought about putting a quick change for the bucket to forks or whatever, I changed my mind and just put 3 hooks,(similar to the 4 hooks on your bucket), and use a 1and 1/2 inch steel bar across the top and hung the forks on that, it hooks up quicker than a quick attach as I don't have to get off tractor to hook it up. the down side is I cant see the forks most of the time. they do hang down about 4 inches below the bottom of the bucket, but still cant see them if there on the ground, In any case they are very handy, just yester day neighbor had me load shingles on his roof, so his son didn't have to carry them up a ladder. We are both in our 70s so don't like ladders anyway.
the grapple part , I have a Hyd thumb on the hoe and use it all the time .
Hope this gives you some ideas , Have fun, Stay safe.
Rich
Exceptionally handy to use, and I use the forks WAY more often than just the bucket.
The problem is: The forks (mine are from an old Clark lift) are heavy, and in front of the bucket, so lift capability is cut way down.
I could lift much more with my set of real Ford forks, but that would mean manually swapping with the bucket.
That ain't gonna happen,
Those Ford forks are somewhere in the barn, under a whole bunch of other stuff.
Doesn't anybody sell QA for excavators in the US for a reasonable price? Here in Scandinavian a lot of manufactors make quite cheap QA, the S type is very common and they make on order custom weldparts for buckets and machine.
I really want a set of forks and maybe a grapple for my backhoe. I知 wanting to convert it to either a 4 point mount like loaders use or SSQA. The conversion isn稚 as straightforward as some tractor conversions since it has the curl cylinder in the middle.View attachment 575708
I wouldn’t think the SSQA would be strong enough for the backhoe. Don’t they make quick attach setups for big loaders? Could you find one of those and fab up your own version? A lot of those machines have the center cylinder too.
