Harbor Freight Tools that don't suck
/ Harbor Freight Tools that don't suck #10,701
I've eyeballed that ball joint press set but don't replace them often enough at this point. Plus some of my cars would get a full control arm over a new ball joint as no one sells just the ball joint. Last time I borrowed one from Autozone. I always need to watch the line between want and need seeing I have limited space and finances.
That Braun bar light for $20 may end up in my workshop though. The coupon is good for quite awhile.
Those lights are awesome. I'm stocking up at this price because I don't want to use a corded drop light now that I'm spoiled by these. They are small, bright, light weight, fit almost anywhere and the banner is very strong. These lights are one of my all time favorite HF items.
I have trucks and Jeeps and I really don't myself going away from having multiple trucks and Jeeps at any time. For dealing with Dana/Spicer axles, the ball joint press is easy to justify, and I currently have 3 Dana front axles in my fleet. Plus these work great on U-Joints and small ball joints in some cars and half ton trucks. It will be a great tool to have for me.
One too love yet to find that my buddy uses... To press the seals into the rear axle of your truck there is a tool that you pick the correct diameter seal pusher, mount them to a center bar that you thread out to expand and it pushes both seals outwards at one time, always keeping them perfectly square to the housing and you thread it out until both seals are seated.
I currently have the one that you tap one seal at a time in with. 20181231_130806.jpeg20181231_130841.jpeg
/ Harbor Freight Tools that don't suck #10,702
By "calibrate the HF meters" do you mean you actually adjusted them to read more accurately, or did you just check how far off they were? If you did adjust them, how did you do it? I haven't opened one up yet to see what they look like inside.
Yes, the HF multimeters have a calibration potentiometer that needs a tiny screwdriver to turn it. I think the size of screwdriver for eyeglasses. As I recall, getting all my meters to match the 1.56 volts of an AA battery still left them with 1~2 volts variance when measuring 120 volts AC.
/ Harbor Freight Tools that don't suck #10,703
Better multi-meters also have a battery test function, for small batteries. They put a small load on the battery and give you a result. Just measuring the voltage doesn't tell you much.
I just tested two C cell batteries, that power the igniter in one of my kerosene heaters. I forgot to remove them last winter, when I stopped using the heaters. Both tested good.
I took one of the free HF multi-meters a couple of years ago and ...... it was crap.
/ Harbor Freight Tools that don't suck #10,704
I'm curious if you can tell by looking if these are the same light as HFs? At $21.99 for a 2 pack they would be a great deal......if it is actually an apples to apples comparison.
https://www.amazon.com/dp/B07C97G8L...&pd_rd_r=da3f104d-0d3e-11e9-a244-c1f675b879f4
https://www.amazon.com/dp/B07BF9KR4...&pd_rd_r=da3f104d-0d3e-11e9-a244-c1f675b879f4
/ Harbor Freight Tools that don't suck #10,705
No, that is not similar. I mean, the form factor is the same I guess.... But the HF version is longer. This one that your link takes me to is 6" total. The HF one is 13.5".
/ Harbor Freight Tools that don't suck #10,706
Thanks for clarifying!
/ Harbor Freight Tools that don't suck #10,707
For most part if I'm checking outlets I use one of the non contact pen style testers.
/ Harbor Freight Tools that don't suck #10,709
Where are you seeing the light bar for $20? I am only seeing $39.99 plus a 25% coupon.
It looks real similar to the one on the Harbor Freight Coupon Database that you obviously are still not looking at!
Seriously, that is a website that any HF customer needs to have saved on their phone it if an Android phone user.... You need to have the application.
The other one is Struggleville – The Undisputed World Champion of Daily Tool Deals who has a web based site and an application.2327_ITEM_BRAUN_390_LUMEN_SLIM_BAR_FOLDING_LED_WORKLIGHT_1544363588.3767-1.jpeg
/ Harbor Freight Tools that don't suck #10,710
/ Harbor Freight Tools that don't suck #10,711
Was looking at their welders today. I will be in the market for a new one this month (it's my birthday). Debating on the Titanium 200 Multi Processor, Vulcan 225 Stick, and Vulcan Omni Pro 220. Both the 200 Pro and the Omni Pro 225 would get me into MIG and TIG that I would, but don't have to, learn. My budget is $800 max.
Who in TBN land has experience with these products? The OMNI PRO has some reviews about the software not being accurate and manual adjustments are required. Problem there is if they update the software to fix; there is not input port to feed the data.
Ron
/ Harbor Freight Tools that don't suck #10,712
RC>> I still use a laptop for my "home browsing"..
SO what I do is, just take a picture of the coupon on the big laptop screen & pull it up when I'm at the register..
instead of TRYING to pull up a website IN THE STORE.. It works great.. unless they wont honor the coupon {tool cart 86-107.00}
/ Harbor Freight Tools that don't suck #10,713
Ron
I would look at Everlast's offerings.
Looking at the OmniPro 220, its rated at
MIG Rated Output:
120V; 100A 19V 40%; 20.8A Input;
240V; 200A 24V 25%; 25.5A Input;
Stick Rated Output:
120V; 80A 23V 40%; 19.5A Input
240V; 175A 27V 25%; 23.7A Input;
TIG Rated Output:
120V; 125A 15V 40%; 20.6A Input
240V: 175A 17V, 30% 15.6A input
That 25% duty cycle for MIG means that you can weld for 2.5 out of every 10 minutes at that power setting.
By comparison, the Everlast PowrtMTS 211SI (which is currently $999) is rated at: PowerMTS 211Si With TIG Package | Everlast Generators
MIG Amps/Volts @ Rated Duty Cycle:
240V
210A/24V @ 35% Duty Cycle/40º C
160A/22V @ 60% Duty Cycle/40º C
130A/20.5V @ 100% Duty Cycle/40º C
TIG Output Amps/Volts @ Rated Duty Cycle:
240V
210/18.4V @ 40% Duty Cycle/40º C
160A/16.4V @ 60% Duty Cycle/40º C
130A/ 15.2V @ 100% Duty Cycle/ 40º C
Stick Amps/Volts @ Rated Duty Cycle:
240V
175A/27V @ 35% Duty Cycle/ 40º C
130A/25.2V @ 60 % Duty Cycle/ 40º C
100A/ 24V @ 100% Duty Cycle/ 40º C
Note that those are at 104F ambient temperatures
On the Vulcan 225, its rated at:
Duty cycle 225A / 29V / 20% (AC), 150A / 26V / 20% (DC)
Everlast has the PowerArc 200STi on sale for $319 (POWERARC 2STi - Stick Welders | Everlast Generators), it is DC only, but has the following ratings:
120V:
120A/24.8V @ 35% Duty Cycle/ 40º C
90A/23.6V @ 60% Duty Cycle/ 40º C
70A/22.8V @ 100% Duty Cycle/ 40º C
240V:
200A/28V @ 35% Duty Cycle/ 40º C
160A/26.4V @ 60% Duty Cycle/ 40º C
130A/25.2V @ 100% Duty Cycle/ 40º C
(waiting on my 200STi to be delivered, should be here on the 8th)
They also have the the i-Mig 200 which does MIG and Stick, currently $639: MIG Welder, Power i-MIG 2 - Everlast Generators
@120V
125A/20.3V @ 35% Duty Cycle/40º C
100A/ 19V @ 60% Duty Cycle/40 º C
75A/17.8V @ 100% Duty Cycle/40º C
@240V
200A/24V @ 35% Duty Cycle/40º C
@120V:
100A/24V @ 35% Duty Cycle/ 40º C
80A/23.2V @ 60% Duty Cycle/ 40º C
60A/22.4V @ 100% Duty Cycle/ 40º C
@240V:
160A/26.4V @ 35% Duty Cycle/40º C
130A/25.2V @ 60% Duty Cycle/40º C
100A/24V @ 100% Duty Cycle/ 40º C
Aaron Z
/ Harbor Freight Tools that don't suck #10,714
I found this thread looking into the Titanium Unlimited 200 welder, and this drove me to reply... as an avid HFT connoisseur this thread is near and dear to me and some of my friends (much to the amusement of other friends, but you guys probably get that too...).
Anywho, there's a whole 3 youtube video's on the Unlimited 200, all with good things to say, and as of last Thursday a whopping 18 reviews on the website... The coupon was for $650 (what the Omnipro was a year ago... where it's $850 now) and expired on the 31st so I acted... went for the extra 2 year warranty for $99 for good measure since I don't have an immediate project for it... welded with it for about 5 minutes with the flux core wire it came with and it did great, now I need to get a bottle so I can go true MIG. I went this route because of the manual settings, I don't want to spend 20 seconds setting the thing up for a 30 second project... plus if the auto settings are off anyway for thick stuff then might as well be manual...
/ Harbor Freight Tools that don't suck #10,715
Rangerfredbob, welcome to TBN. :welcome:
/ Harbor Freight Tools that don't suck #10,716
Thanks Threepoint!
While I'm remembering, there's the free flashlights that used to suck... they aren't 9 LED anymore, they have one good one with a focusing reflector now... now they project a beam of light instead of just some random light going everywhere.. I think I'll start picking them up again... The blue magnetic ones are also improved with one of those strip LED's instead of the array of standard LED's, same if not more light and more focused. I've found they work good for a work light if you pull out the hook and hang it from your shirt neck or if you have a zipper jacket on you can adjust the beam height...
/ Harbor Freight Tools that don't suck #10,717
Both the same price, considered by HF to be the same part... But typical of HF, they have different places making similar built and packaged items that all hang in the same hook.
In this case you notice a slight color variance in the labels as well as one touting Chrome vanadium steel while it's sibling is touting high carbon steel.
Question I have.... What is the better too on my 1/4" impact driver? I would think that CV would be more ductile and less likely to break.... Any metallurgical guys on here that would tell me what they would pick for the $4 with 20% coupon?20190102_153855.jpeg20190102_153905.jpeg
/ Harbor Freight Tools that don't suck #10,718
Thanks Threepoint!
Welcome to TBN, fredbob.
I have one of those small free flashlights as my nightstand light. That thing will throw a beam from our house to light up the front of the barn 60+ yards away. It's impressive. I've used it so much that the switch has started to wear out and it now occasionally flickers a bit. Time for a new one. I also use one of the magnetic oval-shaped ones when I have to go out to close up the chicken coup at night or when taking out the trash in the wee small hours of the morning. Just put fresh batteries in that one this week, and almost forgot how bright it is as well. It hangs by the back door.
/ Harbor Freight Tools that don't suck #10,720
Question I have.... What is the better too on my 1/4" impact driver? I would think that CV would be more ductile and less likely to break.... Any metallurgical guys on here that would tell me what they would pick for the $4 with 20% coupon?View attachment 585610View attachment 585611
I'm what we at work used to call a "Butt Metallurgist" (as in "I'm not a metalurgist, but..." followed by some opinion on metallurgy). I worked in a steel wire mill for decades. We worked with high carbon steel and chrome vanadium. The chrome vanadium is definitely a tougher alloy: it can be heat treated it to higher tensile strengths without getting brittle (there are limits with any alloy, but the limit for most chrome vanadium alloys is higher than for most high carbon steel alloys: that's why you go to the extra expense of the chrome alloy). We used chrome vanadium when a customer needed higher strength, but didn't have the option of simply going to a larger part to get the strength (for example, when weight or space was at a premium).
Having said all of that, it's all in the quality of the steel and the heat treating. Chrome Vanadium is less forgiving of poor heat treating. So this will depend on how well these folks have control of their processing.
iDrive TDS-2010H...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
PONDEROSA PINE TONGUE & GROOVE (A60432)
PONDEROSA PINE...
2020 Kubota M5111D 108HP 4WD Agricultural Tractor (A59228)
2020 Kubota M5111D...
2016 CATERPILLAR M322F MOBILE EXCAVATOR (A60429)
2016 CATERPILLAR...
30KW GENERATOR (A58214)
30KW GENERATOR...
