Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck
Wow, I can think of 1001 uses for these. Picked one up a couple weeks ago, good thing I did they've been out of stock since.
I just got one and it is much brighter than the similar Dollar Tree item. My only complaint is the stiff switch, but for free.......
   / Harbor Freight Tools that don't suck #8,142
A problem with open bins is accumulation of dust and dirt in with the parts, especially sawdust if you're going to do any woodworking. I'm partial to the pullout clear plastic drawers for small parts. Hang two or three of these units side by side on the wall, or stand up at the back of a work bench: 4 Bin Organizer with Full Length Drawer
Fully agree with the need for closed storage- when we first got our barn built, we had hardware in open bins, and even though the barn was closed most of the time, I found that not only was there saw dust, dirt and other airborne debris in them, there were often moths and other bugs in various degrees of activity from mummified to alive and annoying-- hence everything has closed lids now- and like friend Cali above, quart mayo jars have the biggest place, followed by smaller peanut butter and other non-specific containers.
Before the advent of ubiquitous plastic jars, I made a very large storage rack for my dad using baby food jars in a row with their metal lids screwed to a mounting board, so they would hang from them in plain view, but the areas where they could be placed were limited, and there was unavoidable attrition as the glass jars got dropped or knocked off work tables/benches.
I still have that problem, so I hardly ever use glass unless it's for something that will eat or otherwise degrade the plastic ones- and for those I use glass Marchetti salad dressing jars.
I also have some of these:
2 Bin Medium Portable Parts Storage Case
Portable Storage Case
8 Bin Portable Parts Storage Case
That I use to store assorted sizes of things like lag screws, self-drilling screws, 1/4-20 nuts, bolts, washers, etc- so that they're all in one place to choose from. They're not the sturdiest- if they get dropped they can crack and/or pop open, but I have found [by dropping a lot of things] pretty much all similar bins are about the same in durability.
   / Harbor Freight Tools that don't suck #8,143
It's my understanding that the trade-off with the one- or two-pump "racing" jacks is that they require a lot more force per stroke to operate. Have you not found that to be an issue? Although 20 years ago, I don't think I'd have cared!
These jacks use two different pumps operated in tandem by the handle. Altho both pumps always operate, the high displacement pump has a very low relief valve setting. This is plenty to raise the saddle with no or very light load, but vents back to the reservoir as soon as significant resistance arises. The other pump keeps pumping to the lift cylinder and lift rate slows a lot. Handle effort stays about the same rising slowly as greater lift force is required.
If the system of relief and check valves governing the output of the larger pump is flawed the handle effort will increase suddenly as the saddle encounters the load and rise to objectionable at high load. The 1st 2 stage jack I bought exhibits this problem. I didnt use it at high load soon enough to identify and return it. Still a useful jack. I now check others I buy immediately. No other has had the same issue.​
   / Harbor Freight Tools that don't suck #8,145
Awesome. This could get you nominated to the hall of fame. :laughing:
Naw, having no visible duct tape disqualifies it from HOF.
Old magazine ad: "They laughed when I sat down to play the piano...." :)
I got the pole saw running and it cuts the same as it should with the native (NLA) battery. The chain seems to have had little or no use.
But its too clumsy with the bogus power supply attached. I'm going back to my original design: carry the Ryobi battery in a carpenter nail pouch then a cord to the saw.
This photo is with the extension pole retracted. The reach will be doubled when its extended.
Remington had a really goofy design. It's a cordless chainsaw that can be split into front/rear halves when you want to add the extension between them.
I'm happy. For $11 I have the tool I need occasionally. (The extra dollar was for the flea market Ryobi flashlight hacked to be the battery holder).
:D
   / Harbor Freight Tools that don't suck #8,146
I would say the 225pc tool set is nicer than the 301pc.
   / Harbor Freight Tools that don't suck #8,147
i've been eying that also to keep in the truck,
there is a 130 piece with a hammer that i want to give to my son,
as he has absolutely no tools, that'd be good to get him something with torx bits etc,, but that
225 piece is in my sights,, have you seen it in person?
   / Harbor Freight Tools that don't suck #8,148
Picked up one of the little 2-foot 4-outlet power strips for my home studio this weekend. I liked the small size. It powers my guitar and bass amps now.
Also grabbed the light switch using the free (with any purchase) coupon. I mounted it in the closet we had built to cover the incoming/outgoing plumbing where the corner of the old basement kitchen used to be. Lights up that little space just fine.
   / Harbor Freight Tools that don't suck #8,149
I have the 130pc (~$30), 225pc (~$100), and 301pc (~$155).
I bought the 301pc because I had read it was Made in Taiwan. I didn't notice there were two different part-numbers, so I wound up with the Made in China version first.
Bought the Made in Taiwan version and compared them side-by-side. Much nicer. Returned the Made in China version.
I made sure to select a 225pc labeled Made in Taiwan. The sockets in the 225pc seem similar to the 301pc, but the wrenches and pliers are much nicer.
Neither is as nice as the 159pc Kirkland set for around $80.
   / Harbor Freight Tools that don't suck #8,150
I have and use a couple of those too. I like the size and that they are only 4 outlets.
There isn't much inside them though. Very cheaply constructed.
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2012 CATERPILLAR 336EL EXCAVATOR (A51242)
2012 CATERPILLAR...
2016 MACK GU713 GRANITE DUMP TRUCK (A51222)
2016 MACK GU713...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
