Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #10,841
Sorry I have the 20v rechargeable Earthquake. It has reverse but that is all I have seem but will look at it agains
   / Harbor Freight Tools that don't suck #10,842
   / Harbor Freight Tools that don't suck #10,843
So should I buy the 2k inverter generator this weekend at $450? Or will it go down to $430 soon?
It'll be a camper generator, so I don't need it yet (in MI, it's like 0 out)... Hate to get it too early, but don't want to miss a sale.
   / Harbor Freight Tools that don't suck #10,844
They have a coupon for $450 for superbowl weekend, so you don't have to rush... was just at a store today and they had those little coupon things at checkout... I haven't watched the prices on those close enough to tell...
   / Harbor Freight Tools that don't suck #10,845
I'll wait then. I just don't want to pay $50 more by putting it off too long...
   / Harbor Freight Tools that don't suck #10,846
Wonder if yours didn't auto-off correctly or something? But they are "hit or miss" - I've gotten plenty that were real gritty, wouldn't return to zero, would always start up in mm and need changed to in every single time, or simply were off 3-5 thou and wouldn't calibrate to a reference.
Yeah, I've read others comment on the auto-off issue with the HF calipers. Probably the issue with the two I had (still have one of them somewhere). It was suggested I just remove the battery when not in use, but I'm not really interested in all that fiddling when I just want to measure something. Analog works fine for me. Not afraid of a dial or vernier scale (been a professional Quality Jerk for the last 20 years). I never had any issues with the accuracy of mine. They always verified to a standard and zeroed just fine. It was the reliability of the power source that turned me away.
   / Harbor Freight Tools that don't suck #10,847
Or turn it down, mine has 3 settings:
1. "Hand tight"
2. "3/8 ratchet tight"
3. "Did you want the threads pulled out of the nut" tight
I generally use the middle setting to snug down lug nuts, then tighten them with a torque wrench.
Aaron Z
WHen tightenting fasteners, I have several carfully calibrated settings I use.
Tight
Grunt
Loud Grunt
GRRRRRRRRRR
and jump up and down on the breaker bar
   / Harbor Freight Tools that don't suck #10,848
Tight
Grunt
Loud Grunt
GRRRRRRRRRR
Just make sure you say "click" when you get to the proper torque!
   / Harbor Freight Tools that don't suck #10,849
Tight is tight. Too tight is broken.
   / Harbor Freight Tools that don't suck #10,850
I see that HF is now selling the new ultra quiet oil free compressors rated at 60 db. Wonder if anyone has tried one of them. They look the same as my California Air Tools quiet oil free compressor. I can put it in the entryway, run hose to the back bedroom to do trim, and can hardly tell if it is on or off. Some oil free compressors are very loud, but these new models are not.
2 gallon 1.2 HP 135 PSI Ultra Quiet Oil-Free Professional Air Compressor
Well, I need a compressor to replace my pancake that is about to die. Don't want another super loud compressor. I've had a HF vertical, the $149 oil type in the past and it was good for a few years. Looking at the quiet compressors, the 1hp is at the min usable for me as far as cfm output. And for that matter price. I'll not go $499 for a 2hp. With new coupon, the 1hp is just above the California air brand from Amazon or Ebay. I'd rather not order and deal with shipping damage potential. Seems like a 10 percent chance based on reviews. At least with HF I take back and swap in first 90 days.
So, get larger old style or quiet? Same price.
   / Harbor Freight Tools that don't suck #10,851
They are so quiet that it's shocking. You could run in the dining room during Thanksgiving dinner and the sound of forks scraping plates would drown out the compressor sound. I was amazed and shocked.
   / Harbor Freight Tools that don't suck #10,853
It has no power settings that I could see today.
   / Harbor Freight Tools that don't suck #10,854
Concerning the Caliper battery, I take the battery out after every use..
Mine came w/2 batteries & I'm still on the 1st 1.. after 2-3 years.
If u don't use it every day.. take the battery OUT. Its not like u need TOOLS to put it in or take it out..
AND it has a cut-out in the foam protective case FOR IT..
I found myself taking it in & out so often, I cut a relief slot in the foam, to make it easier for my finger to grab it..
   / Harbor Freight Tools that don't suck #10,855
I have one of the battery calipers and 2 dial type. The battery is always dead when I need to use the battery model. Dial ones work everytime.
   / Harbor Freight Tools that don't suck #10,856
I somehow lost the little black plastic cover/holder for the battery on the caliper, which makes it useless. I took it back in and the manager went and got another one and said. "Here, they have a lifetime warranty."
   / Harbor Freight Tools that don't suck #10,857
Safety Recall
   / Harbor Freight Tools that don't suck #10,858
80 LUMEN 12V RECHARGEABLE MINI FLASHLIGHT SKU #64109
The flashlight can overheat while charging, posing an injury hazard for users.
Stop using these flashlights immediately and return to your local Harbor Freight Tools retail store for a refund in the form of a store gift card.
The 80 Lumen 12V Rechargeable Flashlight was sold at Harbor Freight Tools stores nationwide from August 2018 until January 2019.
https://images.harborfreight.com/hftweb/recalls/Flashlight-Recall-64109.pdf
Bought one. Didn't work right. Exchanged it. No idea where the new one is.
   / Harbor Freight Tools that don't suck #10,859
AND it has a cut-out in the foam protective case FOR IT..[snip]
+1 :thumbsup: Since I started doing this a few years ago, I rarely need a new battery. For me, the ease of use of the digital calipers over my analog dial and vernier models well outweighs the nuisance factor of this.
   / Harbor Freight Tools that don't suck #10,860
Yep, the dial ones are dependable for sure. My only digitals are from HF. Curious if the batteries last longer in the high-end brands without removing them.
16ft. Canoe w/ 12ft. Trailer (A59231)
16ft. Canoe w/...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
Case-IH 370 Steiger (A57148)
Case-IH 370...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A59228)
2010 Turfco...
