Harbor Freight Tools that don't suck
/ Harbor Freight Tools that don't suck #7,241
On the original set of 3 I went up to maybe 3/8" mild steel. I broke the hex end off the largest one drilling something thick, it got jammed. I welded a bolt to where the hex broke off and still use it. It cuts fine just a bit wobbly. I was expecting a bit more from the larger set but maybe it just doesn't like thin stainless or it wasn't hardened properly.
Stainless THIN sheet and fairly large diameter drills don't go well together.
Stainless work hardens and as soon as the drill starts to poke through the steel will typically tear - THEN it jams.
Soft(er) backing metal can HELP a whole lot with this.
/ Harbor Freight Tools that don't suck #7,242
For larger holes, in sheet metal, I use a bi-metal hole saw and back up sheet metal with 2x4 or plywood for support.
/ Harbor Freight Tools that don't suck #7,243
Makes sense. Hard to put any backer material on a sick that is already in place. :)
Funny that it was cutting fine until I hit the 7/8" to 1" step.
/ Harbor Freight Tools that don't suck #7,244
As you increase the diameter the speed of the outer edge gets higher as the pressure gets lower (same force, larger cutting area).
7/8 to 1" is about a 15% increase of speed AND about a 12% decrease in pressure.
So yeah, more predictable than "Funny" (-:
/ Harbor Freight Tools that don't suck #7,246
Dragoneggs, just barely managed to get two holes in my bucket to mount the piranha tooth bar on before the shank separated from the cutters.
Even though I do it, you really aren't supposed to use step drills in material thicker than the step segments in the bit. They are for sheet material.
I have got a ton of use out my 3 hf step drills I bought 15 years ago. Alot of it has been in too thick material (makes a cone shaped hole before the biggest part goes through)
/ Harbor Freight Tools that don't suck #7,247
Does anyone know of a site that tracks HF's "lowest prices" like camelcamelcamel does for Amazon?
/ Harbor Freight Tools that don't suck #7,249
I'll bet those prices would look like a slot machine spinning! :)
They do, but the prices would also let us know what really is the "historical" (hysterical ??) lowest price. Like the 26 in., 16 Drawer Glossy Red Roller Cabinet Combo which is $350 as of this writing, frequently $320, occasionally $310 and went down to $295 once last year.
/ Harbor Freight Tools that don't suck #7,250
So last year I bought one of these torches to burn weeds along my garden fence.
Propane Torch
It works pretty well for $20.
I got one of those last year, too. I've used it on the driveways and brick patio, and used it a couple weeks ago to burn along the edge of the lake. Works very well.
/ Harbor Freight Tools that don't suck #7,251
I bought one, back in the 1990's, primarily to light brush piles. It still works like new. It hooked up to a propane bottle that sits in an old plastic milk crate for stability. I just toss it in the bed of Polaris Ranger and go.
I looked at the upgraded version,with the piezoelectric igniter but, decided that the igniter was probably the weak link. I just use a torch striker EZPZ.
/ Harbor Freight Tools that don't suck #7,252
That's a great idea, Rick. Those things definitely get unhappy when they tip over (ask me how I know). ;)
/ Harbor Freight Tools that don't suck #7,253
I had one of the non-igniter models of torch and upgraded to the igniter. It's worth the extra $ to me. So far (about 3yrs) working fine.
/ Harbor Freight Tools that don't suck #7,254
I put my propane tank in a bicycle wheel cart at the back. Balanced pretty good and easy to roll around.
/ Harbor Freight Tools that don't suck #7,257
After a year of denial and one of trepidation, I broke down and bought one of those HF riding mower jacks.I've read more reviews on them than there are apples on a tree. Oh man, used it four times so far. It isn't built like a Swiss watch. Of course it is made in China. I haven't abused it. It works. It is really a handy addition to my mostly old school USA stable of tools. What strikes me the most is a parking lot full of pickups blaring "extreme conservative" sentiments. Ya know. "Make America..........
/ Harbor Freight Tools that don't suck #7,258
Maybe you guys have seen this but I thought the story on the son of the HF founder was interesting:
This Billionaire Made His Fortune on $5 Chainsaws - Bloomberg
I couldn't imagine sending my son to an orphanage because I was "overwhelmed" as a parent when my wife was sick. I wouldn't wish either circumstance on anyone.
Just Wow! That's a must-read for everyone following this thread.
Summary: Smidt is sole owner. He took out $2 billion in dividends in the past 12 years.
/ Harbor Freight Tools that don't suck #7,259
I don't know about this one, but for the money might be worth the chance
Truck Bed Cargo Unloader
I will give this two thumbs up! I have one and have used and abused it...Unloaded loads and loads of firewood, over a ton of #4 stone, topsoil, you name it. One of the handiest things I have ever bought.
/ Harbor Freight Tools that don't suck #7,260
I have one and it works great. Had to buy a mat to put down underneath to reduce the friction of the fabric sliding on my LineX coating on the bed of my F150. You still need to clean out the dirt that ends up on the sides by the wheel wells.
2021 Polaris Ranger Electric Utility Bed UTV (A56859)
2021 Polaris...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
2015 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2015 Ram 1500 4x4...
(2) NOS-8 LUG- 7000Ib 74SC-93 HUB FACE DROP AXLES (A60432)
(2) NOS-8 LUG-...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2022 BOBCAT MT100 STAND-ON SKID STEER (A60429)
2022 BOBCAT MT100...
