   / Harbor Freight Tools that don't suck #7,241
On the original set of 3 I went up to maybe 3/8" mild steel. I broke the hex end off the largest one drilling something thick, it got jammed. I welded a bolt to where the hex broke off and still use it. It cuts fine just a bit wobbly. I was expecting a bit more from the larger set but maybe it just doesn't like thin stainless or it wasn't hardened properly.
Stainless THIN sheet and fairly large diameter drills don't go well together.
Stainless work hardens and as soon as the drill starts to poke through the steel will typically tear - THEN it jams.
Soft(er) backing metal can HELP a whole lot with this.
   / Harbor Freight Tools that don't suck #7,242
For larger holes, in sheet metal, I use a bi-metal hole saw and back up sheet metal with 2x4 or plywood for support.
   / Harbor Freight Tools that don't suck #7,243
Makes sense. Hard to put any backer material on a sick that is already in place. :)
Funny that it was cutting fine until I hit the 7/8" to 1" step.
   / Harbor Freight Tools that don't suck #7,244
As you increase the diameter the speed of the outer edge gets higher as the pressure gets lower (same force, larger cutting area).
7/8 to 1" is about a 15% increase of speed AND about a 12% decrease in pressure.
So yeah, more predictable than "Funny" (-:
   / Harbor Freight Tools that don't suck #7,245
So last year I bought one of these torches to burn weeds along my garden fence.
Propane Torch
It works pretty well for $20.
   / Harbor Freight Tools that don't suck #7,246
Dragoneggs, just barely managed to get two holes in my bucket to mount the piranha tooth bar on before the shank separated from the cutters.
Even though I do it, you really aren't supposed to use step drills in material thicker than the step segments in the bit. They are for sheet material.
I have got a ton of use out my 3 hf step drills I bought 15 years ago. Alot of it has been in too thick material (makes a cone shaped hole before the biggest part goes through)
   / Harbor Freight Tools that don't suck #7,247
Does anyone know of a site that tracks HF's "lowest prices" like camelcamelcamel does for Amazon?
   / Harbor Freight Tools that don't suck #7,249
I'll bet those prices would look like a slot machine spinning! :)
They do, but the prices would also let us know what really is the "historical" (hysterical ??) lowest price. Like the 26 in., 16 Drawer Glossy Red Roller Cabinet Combo which is $350 as of this writing, frequently $320, occasionally $310 and went down to $295 once last year.
   / Harbor Freight Tools that don't suck #7,250
Propane Torch
I got one of those last year, too. I've used it on the driveways and brick patio, and used it a couple weeks ago to burn along the edge of the lake. Works very well.
1996 International Water Truck with a Caterpillar Engine (A56438)
1996 International...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
