Harbor Freight Tools that don't suck
/ Harbor Freight Tools that don't suck #3,902
For that price what do you got to lose?
I agree...I thought about it and read the reviews , watched the video...I'm going to buy it...like you say...nothing to lose...If it breaks right away...I'll get my money back...If it breaks after the warranty period...by that time I will have gotten my moneys worth..
/ Harbor Freight Tools that don't suck #3,903
I was hoping, based on comments on here, that the little 900w 2-cycle generator would be a "don't suck", but now having had one for 6 months, I'm not too sure! I have used non-ethanol, fresh fuel in it exclusively, but it is almost impossible to start. If I remove the air cleaner cover and drizzle in a bit of fuel, it kicks right off. I shut off the fuel valve and run the carb dry whenever I am done using it. It seems to run ok after it starts. Maybe a little lean. So I'm suspecting something wrong in the choke/low speed carb circuit, or it may be that the fuel on/off valve is so restricted that it takes a long time to slowly drizzle a bowl full. Guess it's going back for a trade-in on another.
- Jay
Did you change the plug on it? I've heard that the original plug isn't very good and if you change out to the Champion version, it runs much better. Also, I'd recommend synthetic 2 cycle oil, mixed 50:1 (the Polaris smells a lot better than most), and would NOT recommend emptying out the gas / running it dry as that can cause the carbs to dry out. New recommendation from Stihl is to leave gas in and keep it full.
/ Harbor Freight Tools that don't suck #3,904
... and would NOT recommend emptying out the gas / running it dry as that can cause the carbs to dry out. New recommendation from Stihl is to leave gas in and keep it full.
Which is the best way I have found, years ago... No 'Stabil' used here nor do I run it dry.
/ Harbor Freight Tools that don't suck #3,905
Is that only for chainsaws? Or do you do that with all small engines? I thought running small engines dry at the end of there season was the best thing to do. Is that actually a mistake?
/ Harbor Freight Tools that don't suck #3,906
All my engines.. I did Stabil and the run dry thing at first and ALWAYS had problems the next year. After just leaving it in I have very few. Once in a while I have to pull a bowl and spray a little carb cleaner, but no other problems.
/ Harbor Freight Tools that don't suck #3,907
Ok, thanks for clarifying. With no additive and the running dry thing, I have had zero problems. So I'll stick with that. Other than air filters and oil changes, where applicable, I have had zero issues with small engines.
/ Harbor Freight Tools that don't suck #3,908
I shut off the fuel and run the carbs dry on all my engines. ZERO problems.
/ Harbor Freight Tools that don't suck #3,909
We really don't have an "off season" at the ranch, we run everything year round. We don't shut gas off, run dry, on anything and only run some Stabil in the Corvette which gets driven in Houston for 3-4 days a month.
We have very few gasoline engines, a JD Z820A zero turn, Polaris Ranger, and various Echo chains saws, brush cutters, and power blower. Everything else is diesel.
Rick
/ Harbor Freight Tools that don't suck #3,910
Rick
Well, you're in Houston. That's kind of like cheating :). I probably wouldn't stop using my mower or tiller or trimmer, etc. And I might never put gas in my snowblower, because...its Houston. :D
I bet they don't pour salt and calcium chloride on the road everyday, either. So your cars look all nice and newish. Yeah. Cheating.
Hmmm. Maybe I'll move to Houston :drink:
/ Harbor Freight Tools that don't suck #3,911
Max;
My two brothers still live in Mid-West and I remind them, by late November every year, that "I don't own a snow blower nor do I ever want to". Mowed the yard around the ranch house ( about 8 acres) between Christmas and New Years, mostly to mulch all the oak leaves.
Rick
Edit; You are welcome to move to Texas. We have lots of room and lots of Jobs.
/ Harbor Freight Tools that don't suck #3,912
Max;
Rick
SHHHHHHH! I like the quiet of no neighbors for a mile.
/ Harbor Freight Tools that don't suck #3,913
- Jay
I had a cheepie cummings tool generator and the fuel hose that went from the tank let little bits of hose chunk off into the carb and clog the jets so I replaced the hose and cleaned the carb. No probs since and starts easy.Of course I also use high octane leaded fuel in it but I do that in all my 2-strokes.
/ Harbor Freight Tools that don't suck #3,914
I have the same generator, and after the break in period, and after not always running smoothly, I swapped the spark plug out for an NGK BP5ES3, and it purrs now. It seemed to really make a big difference. I actually recently swapped out all of my small engine plugs for ngk plugs, and they all seem to like them much better. The only other thing that I can think, is that the fuel should be very fresh. Thats great that you can get ethanol free gas. In my area they have outlawed it, including the surrounding two states. They state governments actually passed statutes requiring a percentage of ethanol in fuel at the pump. The only gas that I can get without it is in the small cans at Homedepot, and Tractor Supply, but that is almost double the cost at the pump. I use Startron, and it has been an absolute lifesaver. I also switched to Stihl synthetic in all of my 50:1 2 cycle engines, and that has also seemed to help out quite a bit. I was schooled, if you will, after returning a new saw years ago, that I could not keep running. They private dealer, said that they see multiple saws, and two cycle engines every week that people run old fuel in, with cheap mixed oil, and it always causes issues. I am not sure why 2 cycle engines are so fussy, but I now only keep a gallon on hand of fresh gas, and I have not had an issue at all with my 2 cycle engines, and I have 6 of them. That may not be your issue at all, and it sounds like you are doing the right things, so it may be a dud, but try the plug if you haven't. My brother has the same Generator, and he uses it on his boat, and he recently (last week) had the same issue. he changed the plug, and it fixed the problem.
The only other issue I had was my starter cord broke, and I found out that it is a complete piece attached to the cover, but they are cheap on ebay brand new, so I bought one for around $15, and it works great again. If you don't have a warranty, the carbs are very inexpensive on ebay also.
Good luck with it, and let us know!
- Jay
/ Harbor Freight Tools that don't suck #3,915
I got one of those stair chisel tool. not too bad. I literally abused it with a hammer tucking carpet in. only thing is I wish it was one inch longer so my hands is further away from hammer end.
/ Harbor Freight Tools that don't suck #3,916
Max;
Rick
Thanks for the invite :thumbsup:
Texas is a beautiful place. I have lived there and visited.
I hope Texas continues to be prosperous and successful. It is a shining star in our nation. In another part of this forum, we could discuss why that is. There are some who want to change that.
/ Harbor Freight Tools that don't suck #3,917
howdy neighbor. I said it quiet like, so as not to be too disturbin' to ya. :D.
Course, everything's bigger in Texas, so a real Texas Howdy is more like H O W D Y ! ! !
/ Harbor Freight Tools that don't suck #3,918
They sell a little 110v inverter stick welder that is white or light tan in color. It is really small about as big as a box kleenex. It goes on sale from time to time for about 140$.
It is the very handy. I break it out for a quick weld from time to time. I keep it in a small size plastic box like a tackle box. It uses 3/32 or 1/8 in rods.
I like it a lot. being 110v it can go anywhere there is a plug.
/ Harbor Freight Tools that don't suck #3,919
It's in this week's Inside Track coupons at $130 - good through next Tuesday 1/7. (Or 'Sale' price $150 on the website). Most of the reviews are favorable.
/ Harbor Freight Tools that don't suck #3,920
Here is the one I am talking about...it is $19.99 with the coupon code...what do you think...? good deal or not...? Thanks
Reciprocating Saw w/ Rotating Handle
I bought one of those and it burned out within 2 hours of VERY occasional use cutting on 2x4 soft pine. I've used my Milwaukee for hours straight cutting deck nails and 30 year old hard as a rock deck boards.
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
2013 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59230)
2013 Chevrolet...
2015 DODGE RAM 3500 4X4 CREW CAB PICKUP TRUCK (A59904)
2015 DODGE RAM...
2004 Takeuchi TL150 High Flow Compact Track Loader Skid Steer (A59228)
2004 Takeuchi...
2017 Ford F-550 Service Truck (A59230)
2017 Ford F-550...
