Harbor Freight Tools that don't suck
/ Harbor Freight Tools that don't suck #3,881
Now you have ask yourself what could POSSIBLY go wrong with buying hammer from HF?
Well let me tell you :D
I bought this 2lb double sided brass faced hammer what piece of work that was. The first time I tried use it the head came flying off. It was just secured with just a wooden wedge (a design that which a lot of tools once used (like back in the stone age lol) The handle fit was so loose in the hole in the cast iron head it wouldn't hold tight so I used a silicone adhesive and double wedged it. Its had a pretty good workout since then and usually the first persuader I grab most times so I guess NOW it qualifies as a HF tool that doesn't suck too.
/ Harbor Freight Tools that don't suck #3,883
Multiple times in this thread I have argued that hammers are the best deal from HF. They seem to have a knack at making the right weight and handle as long as you can live with a Chinese wood handle and are willing to search through the racks for one with the head securely attached. This is not a mail order experience.
I've got one hammer--maybe a photo later today-- that I would not sell unless the price was right and I could exactly replace it. :)
/ Harbor Freight Tools that don't suck #3,884
I've had more expensive hammers than HF with loose heads, but ya.. I drip in some epoxy and let it soak in and harden. No more problem. Ever :)
/ Harbor Freight Tools that don't suck #3,885
Rapid Pump 1.5 ton aluminum racing jack #68053/69252/60569 anyone have this? $69.99 with coupon. Wife got me a 3 ton one that ways a ton for Christmas. I dont have paved area or garage, so I cant roll it around and a light weight one would be nice. Would be used on impala, highlander, dakota, and 2500hd gas (6000#).
/ Harbor Freight Tools that don't suck #3,886
Not sure exactly which aluminum jack I have but it's light as a feather and I love it. Also have the heavy steel ones and really try to avoid using them because they weigh so much.
/ Harbor Freight Tools that don't suck #3,887
1.5 ton is 3000lbs.. I would get a heavier duty one for use on the truck..
/ Harbor Freight Tools that don't suck #3,888
Ayep. We had a 1.5 ton one and it didn't have the power or height to lift up our pickup (1997 Dodge 1500 4x4). Replaced it with a 3 ton one and its been good for ~8 years now.
Aaron Z
/ Harbor Freight Tools that don't suck #3,889
I have one of the 1.5 aluminum jack. I have used it on a Honda CRV and a Jeep. It did raise them but I do not get a good feeling using it. I have used it for other light duty tasks around the farm. I have a welding trailer and, for extended leave of absence, I remove a wheel. It handles this job perfectly.
I carry a HF steel 2.5 ton jack when I haul my trailers. It sure weighs a lot. Most of the time I do not need it. But, on a trip from FLorida to Texas with a heavy load on my lowboy trailer, I used it twice. My old tires seemed good for the trip but it turned out I was wrong. I blew one tire, put on spare and bought 3 new tires which is all Walmart had. Eighty miles from home I blew the last tire. I made it home on a very old spare. I now have 4 new tires with one decent old spare. I am thinking of buying the HF 3 ton aluminum jack for easier portability.
/ Harbor Freight Tools that don't suck #3,890
I had one of the "racing" jacks. Wouldn't buy it again. It was a quick pump and when lifting near it's limits it took a lot of force. It's one thing for a racing team to need to raise a car off the ground quickly but 4 or 5 pumps (vs 2) is fine by me.
/ Harbor Freight Tools that don't suck #3,891
Now that is a good point. I, too, noted on my 1.5 ton that it took more force when lifting near its limit of travel. Something to consider.
/ Harbor Freight Tools that don't suck #3,892
Diamond blade wet saw, $50. Works great and allowed me to do my whole bath ceramic tile project without renting any tools. Water tray is hard to remove without slopping water.
On the HF wet saw I found it is easier to have a fresh water 5 gallon bucket to set the sump in and a separate bucket to catch the used water in. It is easy to dump and no filter clog. This experience was gained after 10,000 clay pavers - and the saw still works great - used only 3 blades.
/ Harbor Freight Tools that don't suck #3,893
I was hoping, based on comments on here, that the little 900w 2-cycle generator would be a "don't suck", but now having had one for 6 months, I'm not too sure! I have used non-ethanol, fresh fuel in it exclusively, but it is almost impossible to start. If I remove the air cleaner cover and drizzle in a bit of fuel, it kicks right off. I shut off the fuel valve and run the carb dry whenever I am done using it. It seems to run ok after it starts. Maybe a little lean. So I'm suspecting something wrong in the choke/low speed carb circuit, or it may be that the fuel on/off valve is so restricted that it takes a long time to slowly drizzle a bowl full. Guess it's going back for a trade-in on another.
- Jay
/ Harbor Freight Tools that don't suck #3,894
- Jay
/ Harbor Freight Tools that don't suck #3,895
Interesting note relative to Harbor Freight. I happened to go into a Home Depot today and saw many Chinese tool products pretty much the same as Harbor Freight carries. Now, some were on sale but many items were cheaper than what they would cost at Harbor Freight.
Things I saw were cut-off tools, grinders, impact guns, hand tools and such. Surely this has to be having an effect on Harbor Freight?
/ Harbor Freight Tools that don't suck #3,896
HF...has a 4&1/2 inch grinder on sale right now for $12.00 and change...with a coupon even less but I think only good until this Friday...They have a reciprocating saw for only $19.00 ...again until Friday....I bought the grinder and will go this Friday and get the reciprocating saw...too cheap - I have to buy it...LOL
/ Harbor Freight Tools that don't suck #3,897
There are two recipro saws - a cheap one and a almost-tradesman one that has a higher amp rating (more power) and higher cost. I don't think I've ever seen the better one go on sale.
I have a couple of the $10 grinders. They are fine for occasional use and for running a wire brush.
/ Harbor Freight Tools that don't suck #3,898
Here is the one I am talking about...it is $19.99 with the coupon code...what do you think...? good deal or not...? Thanks
Reciprocating Saw w/ Rotating Handle
/ Harbor Freight Tools that don't suck #3,899
I don't have experience with either. In my experience HF power tools are generally less powerful than tradesman-quality tools (that cost more), so HF's more powerful choice will be more satisfactory. But their overall quality is improving, and now there are fewer dogs in their product lines.
In this particular case HF's Customer Reviews for each model should be a good guide. (and I see there are now 3 recipro saw models).
24in excavator tooth bucket (A61306)
24in excavator...
SCAN TO RECEIVE TEXT UPDATES (A60429)
SCAN TO RECEIVE...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
UNUSED SDLANCH SDLGC100 ELECTRIC GOLF CART (A60430)
UNUSED SDLANCH...
Hydraulic Concrete Breaker Excavator Attachment (A59228)
Hydraulic Concrete...
