Harbor Freight Tools that don't suck
/ Harbor Freight Tools that don't suck #301
Bah!
Here's a HF gotcha.
The little 95498 compressor looks good. That website description and their paper catalog show it has the highest output among their similar models:
5.0 CFM @ 90 psi, 7.1 @ 40
So I downloaded its product manual.
The real specification in the manual is right in line with its price point:
2.9 CFM @90 psi, 5.8 cfm @ 40.
Like building a real tool out of HF components, it looks like you need to get past HF's advertising specifications and research the manufacturers real specifications before putting up your money.
And I'm still curious why this unit is rated in CFM, while the peers of its bogus, inflated(!) 'advertising' specifications are rated in SCFM. I'm not going to buy it now so I guess that doesn't make any difference.
/ Harbor Freight Tools that don't suck #302
California said:
Bah!
Here's a HF gotcha.
It is entirely to be expected that a compressor will have a max pressure rating and a max air flow rating and the two are NOT AT THE SAME TIME. Hence the only "fair" way is to rate CFM at "some pressure" which turns out to be 90PSI for most engineers.
Specsmanship certainly sucks, doesn't it?
Pat
/ Harbor Freight Tools that don't suck #303
patrick_g said:
Dargo, If you aren't comfortable the rest of the discussion really doesn't count. If you can get a comfort factor by spending a few bucks more it is definitely worth it to you and I'll not say you are wrong.
I'm not sure I follow you. I realize that you are the biggest HF fan here by far, but some of their products are nothing less than dangerous. I fail to see where "the rest of the discussion really doesn't count" when I am pointing out some facts about the dangers of some of the poor quality items HF sells that can be very dangerous to the user. Just because I am most definitely not their number one fan does not mean that my observations, or other's observations, don't count. I don't have the time to go the thread about the HF tools that suck to list most everything they carry. I simply thought it appropriate to mention being careful with buying the absolute cheapest item available when you in fact are trusting your life to that item.
/ Harbor Freight Tools that don't suck #304
Dargo you do realize that maybe your experiences are not the norm. You might have gotten hold of an item that everyone else has had good luck with and you just got the lemmon. I have had very good luck with my harbor freight purchases. Maybe they were not as good a quality and items that sell for a lot more money but for the use I have needed them for they have worked well. I bought a set of the HF impact sockets. I used them on my ingersol rand impact drive and they worked perfectly. The did not break or fly apart on me. I have used the heck out of my tile saw and the blade on it did not shatter into a million pieces when I cut things with it. I value your opinion and enjoy reading your posts. But if you are saying that because something broke while you were using it and now that whole line of tools is dangerous. I think that just one instance of something breaking does not brand a whole line of tools as so dangerous you cant trust you life to it.
/ Harbor Freight Tools that don't suck #305
Maybe I didn't take the time or space to write it out properly, but I feel that there is nothing wrong with buying cheap products at times. However, I have to draw a very strong line when I know for a fact that some of the cheap products can flat out be dangerous. I'd gladly take all the fuss from the Harbor Freight Kings on here if just one person is saved a serious or fatal injury from buying a substandard product from them. I have not taken any HF jack stands in for testing in a lab, but I value my life more than the $10 or so that would be saved by purchasing the cheapest jack stands available versus buying jack stands that are of a known and proven quality.
I shattered each and every deep well impact socket I used from the cheap set I bought at HF. I took the first set back and shattered the very first socket I used in the replacement set. In my book that is enough proof that not only are the deep well impact sockets from HF junk, they are potentially dangerous. The same goes for the chop saw blades. I had several self destruct during use and I never had any fly apart before I bought the cheap HF ones nor have I ever had any fly apart since. Again, that is enough for me in good conscious warn others about the danger of buying the junk chop saw wheels from HF. That doesn't even mention the most dangerous item I've ever bought there; spring compressors.
I'm very well aware that some guys here have their entire garage or barn stocked with nothing but cheap stuff from HF. It's their money and their business. But, as I mentioned earlier, if I can save one person from getting hurt from substandard Chinese junk it's worth mentioning. I see nothing wrong with buying cheap volt meters for general use there or some other hand tools that will be only used very infrequently. Those generally won't be dangerous. But, I can tell you that a $1 paint brush isn't worth anything to me when all the bristles come out and end up in my paint. :mad: And, I'm not so sure a wire brush is worth a buck there when all the wire bristles fall out on the first use. To me, some stuff is worth the risk but other stuff than can hurt you is in no way worth the risk.
/ Harbor Freight Tools that don't suck #306
Not trying to set anyone off but that is really weird Dargo:eek:
I've got a full set of 1/2 drive deep well HF impact sockets in both metric and SAE, I've abused the fool out of them with a 600 ft lb impact wrench (Ingersol Rand) and never broken one.
I've also never had all the bristles fall out of their wire brushes, of which I've bought many, in all sizes from toothbrush to big ones, bet I've got 12 in the shop right now.
Never had trouble with their paint brushes either.
I have thousands of dollars worth of their products and overall they've been great, rarely ever had to return anything, in fact I used to get suckered in on their extended warranties and don't buy them anymore either since I never had an item fail to get warrantied. I also have many more thousands of dollars worth of name brand Craftsmen, Ryobi, Milwaukee, and you name it tools so I'm not just a HF junky.
Are you just jinxed:cool: :D
/ Harbor Freight Tools that don't suck #307
Has anyone had good luck with HF's #90385 compressor?
2.5 HP, 8 GALLON, 120 PSI AIR COMPRESSOR, $159.99.
This seems to have the best specifications of all the smaller compressors, the ones that are reasonable to lift into a truck. (65 lbs).
Also, my used tool buddy has a 30 gallon compressor tank with its compressor gone. Will it work to put a T fitting on the output of this little guy and use that larger tank as additional buffer to provide more air to air tools before the pressure sags? Will this be usable (after adding filters) for painting?
I expect this will be light hobby use, a few hours per year, so I don't need pro grade stuff.
/ Harbor Freight Tools that don't suck #308
Dargo, You say you are not sure you follow me. I'm positive you didn't. Let me try again. IF YOU aren't comfortable with a certain quality level then paying a few more bucks to get into your comfort zone is NOT something I would quibble with and agree it is the right thing for you to do.
As to the "REST OF THE CONVERSATION" comment, you really missed on that one. Don't be so defensive. You were not being attacked. What I was saying is that if you aren't comfortable at a certain quality level then the rest of the conversation (the other stuff I would be saying) doesn't matter. Until or unless the tool in question meets your minimums, nothing I say would matter.
Now as to your impression of me being HF's biggest fan... I'm not sure about that. I use HF for what it is, a supplier of less expensive stuff and a convenient wide variety. Sometimes their stuff is a good deal and sometimes not, often depending on the intended use so a particular tool could be a good deal for one guy and a bad deal for another. I don't view it as an all or nothing proposition.
If I were truly a mind dead robot carrying a HF fan club charter member card then I wouldn't have so many Milwaukee tools as well as DeWalt, Delta, and such. If I were really into HF I would have an HF sliding compound miter instead of a DeWalt AND a Milwaukee. Price a Saw Stop brand cabinet saw and compare to any table saw at HF. My second tier table saw is a Makita. I'm not bragging just making a point about not being hard over in the HF camp.
I am not an all or nothing kind of guy. It takes more effort to have to make rational decisions on a case by case basis, considering your intended use and you expectations regarding quality, longevity, and such. I consider risk management and economics. What is the down side if the HF tool fails. Will it be safety hazard and of what proportions? Will it be just a minor glitch or will it be a major hassle with no available workarounds?
If A tool has to be depended on for rugged performance, take abuse and keep on chuggin' and a free replacement is too much hassle, I scrutinize it closely as a candidate for a Milwaukee or lesser tools like Dewalt, Delta, and such. When it comes to welders I have no HF gear. I have a Lincoln AC/DC and a Lincoln MIG and my plasma is a $2K HyperTherm made in the USA. I wear a HF auto darkening helmet which is way better than my old US unit.
I neither universally condemn HF nor am I a blind supporter of HF. I take things on a case by case basis and try to get the most utility for my $. In many cases I have HF tools which perform adequately and in some cases spectacularly, especially considering the price. I have wasted a few $ with HF getting useless junk but have become more circumspect over the decades of my shopping there.
HF is NOT a religious issue with me. I could be going with good American stuff like Sears Craftsman, right? My new Craftsman compressor has a defective pressure switch. They mailed me another one. It is defective. I spent 45 min on the phone this AM and never got to talk to a live person until I hung up and tried a different tactic. I got to talk to a live person, somewhre overseas who connected me with another telephone menu system which ultimately told me they weren't open and hung up on me. Ahh, American quality service. HF does it better.
You will note that there are folks who really go out of their way to put down HF and the people who buy their stuff. Interesting but there doesn't seem to be many people putting down anyone for buying the big name American brands. I wonder what that means, personality wise?
Pat
/ Harbor Freight Tools that don't suck #309
Patrick, really, I have no low opinion of you because you really like HF. I've made it a point on this thread to post where I do own HF items that have proven to not only be a good value but, in my opinion, a really nice item. I only mentioned that I'm aware that you're a big fan of theirs because by far you are the biggest supporter of HF in this thread and I knew you'd take issue with me pointing out the facts of what I consider dangerous items they sell.
I feel that I've given HF far more than a fair shake on buying their off brand stuff and have found that most of their off brand power equipment is just plain junk and several items are, without a doubt, dangerous. I will still shop there for the occasional item and take the gamble; which I believe is the case when buying their products. I have worn the wheels off of my low rider creeper and can buy one at HF for less than half of what a quality one costs. I figure I'd give it a try. I don't see where a creeper would be dangerous if it failed. I also have a need for some odd size hex wrenches that will be used very little. Again, I figure I'd give HF a try. My guess is that as long as I don't have a hex bolt stuck and I really have to torque on it to get it out, the HF cheap stuff should be fine. I need to paint some outside steel posts. I got burned buying their cheap brushes that left dozens of bristles in the paint last time, so I figure I'd try their foam brushes this time. Hopefully the foam doesn't come apart and stick in the paint, but I figure I'd give it a try since I plan to toss them after use.
I could go on and on about items there I feel are worth the gamble but there is no way anyone can convince me, after indisputable evidence to the contrary, that some of their items are not only junk, but defective and dangerous. As I said earlier, I'm willing to have the people who love HF be ticked at me if one person is spared injury or death from products that HF should not even have on their shelves. How would you feel if you were seriously injured by a spring compressor from HF only to find out later that others knew for a fact that their compressors were substandard and dangerous? Wouldn't you rather know going in that you positively must treat that tool as if it were a bomb getting ready to go off? I feel firmly that it is better to be informed of potential serious issues with an item rather than be ignorant of that fact. That is my point here. Be mad at me, but if you have just a bit of extra caution in mind when using any of their items that could hurt you, it's worth it to me. Heck, one serious item in my signature is the HF yellow handled claw hammer. I have several very expensive claw hammers from when I was building my house and guest house and I prefer the cheapo HF claw hammer. It has better balance and feels better in my hand. I consider it not just a good value, but a darn good claw hammer! (Ha, now let's see if anyone goes out and buys one since someone who is very cautious about HF heartily endorses that item :))
/ Harbor Freight Tools that don't suck #310
Well the wife and I were in HF this morning and I found this-Harbor Freight Tools - Quality Tools at the Lowest Prices
a 15" locking pliers.
Wife asked what I was going to use it for- I said I had no idea but when the application came up, and I'm sure it will, it will be just the tool for it:D
/ Harbor Freight Tools that don't suck #311
Those are super long pliers, I have bought several locking welding pliers and they arent the best, but served the purpose..
I use the small locking pliers like that that are a brand name tho. I might be overusing them but they are sure Worth their money.
/ Harbor Freight Tools that don't suck #312
I bought one like that last year on sale for $99 and it was the best $99 I ever spent. :) It is used almost daily to air up tires and works great with my nailer and sprayer. I had a Campbell Hausfield that was a little larger and much heavier and it could not keep up as well with my air demands.
/ Harbor Freight Tools that don't suck #313
tallyho8 said:
California said:
... good luck with HF's #90385 compressor?
Thanks! That's exactly what I was hoping to hear!
/ Harbor Freight Tools that don't suck #314
Dargo,
I apreciate that you want to warn people to a potential safety problem with some of the HF tools. What were you using the impact sockets with. You said that you went through all the sockets in two sets. Two of us on here have posted that we had them on good quality IR impact wrenches that have a maximum output of 600 foot pounds of torque. I have never had problems with the ones I bought and evidently neither has the other poster. What kind of Impact do you use that broke them that badly. If there is something that I might do that makes them break easily i would surely want to know that.
I have used the 4 inch cutting disks a lot and no problem. My friends tell me to get the HF band saw blades they work well and last as long as anything else. Most of the guys I work with have their cheap metal band saw. It works very well for the average home use.
I have been to Pats house I try not to go out in his work shop because I am afraid that I will rust some of his tools because I am drooling so much. There are a lot of people on here that do not have to buy at HF we try to spend our money for the best investment in tools for the buck. I personally spend a lot of money on Ridgid power tools. They are pretty expensive comparatively but they have a real lifetime warranty and they work very well. For a one time use or something I am not going to use very often my money is well invested in HF stuff. Sometimes before I want to invest a 1000.00 or more in a tool I try an HF tool to see if it will do the job and if I am going to use it enough to warrant the better tool. Usually the times I have done that I have not bought anything else because HF does the job. Like pat said I am getting more discriminate in what I am buying. One of the things that I have seen poster after poster talk about is the HF auto darkening helmet. I have not seen a post yet where someone said it did not work as well or better than any auto darkening helmet they have had. and for 50.00 it is well worth the price. But I for one am very appreciative of your stance on wanting to help people avoid dangerous situations.
/ Harbor Freight Tools that don't suck #315
I actually don't see a difference in what Dargo and Patrick are saying...
Basically, some HF tools are good, some (probably most) aren't, buy with your eyes open.
I'm annoyed with them currently as have had a bad run of luck. Cheap winch worked once with no load on - hoping I can fix it. But didn't have high hopes in truth, bought it to play with it.
I'll say this for HF - their junk is junk priced. Whereas some out there are selling the exact same junk (like the winch I'm talking about) for far more - I've seen the same winch rebranded elsewhere for twice the price.
What annoys me is not HF junk being junk - I expect that. My new Dewalt being junk is thoroughly irritating.
Patrick, am I right you are happy with the saw stop saw? I've heard good things about it, and am on the edge of pulling the trigger. Thinking the contractors saw for now, maybe get the cabinet too for later... Expensive, but normally I, or the guys working for me, strip the blade guard off the saw first thing, and that could be far more expensive... Was thinking the new bosch as a jobsite saw before sawstop came out with the contractor
/ Harbor Freight Tools that don't suck #316
oh, I meant to say - I have the chainsaw sharpener - very poorly built, but works well, if that makes sense. Bought the circular saw sharpener, in the hope that it'll save me a fiar bit of cash if it works, but haven't tried it yet.
/ Harbor Freight Tools that don't suck #317
tallyho8 said:
I bought one like that last year on sale for $99 and it was the best $99 I ever spent. :) It is used almost daily to air up tires and works great with my nailer and sprayer. I had a Campbell Hausfield that was a little larger and much heavier and it could not keep up as well with my air demands.[/QUOTE
I've had one for nearly two years. Almost identical but over here its labelled as GMC. I've seen them as low as $98 but I think I paid about $125 including an accesory kit. I'm pretty happy with it. (In fact I dont know how they can be made for this price). The tank is just big enough for topping up a couple of tyres before the motor starts up. I've never used it for spraying. The only problem I had was a split in the hose near one of the connections. My only real gripe is the low handle and narrow wheels. Its kinda clumsy if you have to drag it around. But its light enough to lift into the trailer or back of the wagon.
/ Harbor Freight Tools that don't suck #318
Only used them a few times so far, but the Pittsburgh brand swivel end ratcheting box wrenches seem well worth the money for the backyard mechanic type.
/ Harbor Freight Tools that don't suck #319
The Saw Stop cabinet saw (I have the 52 inch table) is a heck of a fine machine. A brief momentary lapse while using a tapering jig and ZHAZAM. I had a spare cartridge for just in case. Now you see it (the blade) and then poof, you don't. A previous lapse using the Makita customized my left thumb to the consternation of several national agencies who have to change their files.
A report on cabinet saws I read gave the stats on several very nice saws. The Saw Stop was as good or better in every measurement of tolerances, runout and such. It is not just the safest saw it is also about as good as saws get.
I mostly use it without the guard but with the nice riving knife. It is pretty easy and fast to swap back and forth between riving knife and guard. It is pretty easy to change blades from 10 inch to 8 inch dado stack and takes 2-3 min extra to swap from 10 inch brake cartridge to 8 inch brake cartridge.
My single complaint is that I would have liked a teflon coated table or chrome or... I hate to see where my sweat causes rust. I have a set of cleaners that make it look new though.
If the Saw Stop contractor's saw is as good compared to other contractor's saws as the cabinet saw is compared to its brethren, it will be a good machine.
Pat
/ Harbor Freight Tools that don't suck #320
I really do like HF (much of the time) and I also really like my several Milwaukee power tools, Delta, Senco, Craftsman (well not all that furiously in love with Craftsman in many instances), Ryobi, DeWalt, and on and on. I'm sure I have less money tied up in HF than the others.
What my "LOVE AFFAIR" (if it is fair to call it that) with HF is that I don't always need the best of everything and sometimes HF fits well within the "GOOD ENOUGH" category. I could post on the HF tools that suck thread too.
I don't give blanket approval nor condemnation to a whole store full of stuff because I like or dislike some small percentage of their products. I consider my HF purchases on a case by case basis and evaluate their expected utility and economy to me based on my expected use. Sometimes I am pleasantly surprised and sometimes not so pleasantly surprised. Overall, I have had a positive experience with more satisfaction than disappointment by far. Without expectation there is no disappointment and I sometimes don't expect a lot from HF goods.
Bottom line is that if it didn't work for me as well as it has I would be much less inclined to spend $ there. There is just a whole lot of the stuff in the store and on-line that I would never buy because it doesn't pass muster with me. They have some stuff that I wouldn't want at 90% off retail and free shipping.
I'm sorry you have had such a negative experience with HF. If I had done as poorly with them as you I would probably not shop there often.
I have some of their heavy clunky Crescent type wrenches up to 18 and 24 inch size. I don't need them very often but I can't see how a better brand would work any better. Maybe be lighter using a stronger alloy but no more than I use them heavy is no big deal AND they are guaranteed forever, instant exchange, no receipt, no hassle. I had a wood working fast clamp break first time I used it. Free exchange, no receipt, no hassle. I have lots of clamps so having one break was not a hold up.
If I think I need to really really depend on something and it is not just an inconvenience if it breaks but a major hassle then I am pretty darned circumspect about what I buy. I have a Warn winch (12,000 lb) on my truck, not a HF.
I do have a couple different sets of Chinese made impact sockets (one set from HF but only driven with cheap Chinese impact tool and air ratchet) and they have lasted for over 10 years. I don't make a living using them every day but I have used them seriously several times.
Pat
2016 Nissan Sentra Sedan (A59231)
2016 Nissan Sentra...
2022 Horizon (A55973)
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2007 Ford Taurus Sedan (A59231)
2007 Ford Taurus...
Forklift (A56857)
Forklift (A56857)
