Harbor Freight tilt meter (cheap)
/ Harbor Freight tilt meter (cheap) #2
I have never used one but I wonder how you calibrate it to your tractor since each tractor may tip at a different angle depending on a number of variables.
I'd like one for my 355D. I have been using the pucker factor. That is my only tractor that works a slope.
/ Harbor Freight tilt meter (cheap) #3
I have a tilt meter... it measures tilt in both directions... side to side and front to back. I find that the ball rolling in a viscous fluid is good, else it would be sliding all around as the tractor jounces around. Go ahead and get the item from HF... see if it works for you. Be well aware that there is no single angle, even for the same tractor, that is safe... all depends on load, where it is carried..front, back, high, low... and ballast the tractor has. I've had a wheel off the ground numerous times... and the angle was low.
Net... try it... you'll learn a lot and not spend much money... and, go slow anyway and be ready to drop your FEL or 3PH load when a wheel comes off the ground.
/ Harbor Freight tilt meter (cheap) #4
/ Harbor Freight tilt meter (cheap) #5
</font><font color="blue" class="small">( <font color="blue"> </font> Be well aware that there is no single angle, even for the same tractor, that is safe )</font> <font color="black"> </font>
I guess I'm a bit dumb but I don't see what good a meter is if you don't know what is safe. I suppose for someone who can't read the slope they are working on it would be OK. But then, where to stop? Still sounds like gut feel.
I would only want one if it was set for my tractor and had a "red line" like my airplane. Even then you have to be careful of holes just like turbulance.
/ Harbor Freight tilt meter (cheap) #6
/ Harbor Freight tilt meter (cheap) #7
I doubt it will work but for $10 give it a try (note I have guesstimated true cost after S&H). This is an undamped device and the needle will be swinging all over the map and will not provide any useful information.
I got one from R&B (www.tiltmeter.com) who is well known here at TBN. It is marked with the "usual recommended" ranges in color, white to 15, then yellow then red at 20 if I recollect correctly. Works well and I highly recommend it. It helps to calibrate my PPP (personal pucker phactor).
/ Harbor Freight tilt meter (cheap) #8
2018 F-150 4WD (A63688)
2018 F-150 4WD...
17601CFL (A61572)
17601CFL (A61572)
(1) 74"X49" TAILGATE (A64280)
(1) 74"X49"...
X-STAR 30,000lb Ramp (A64119)
X-STAR 30,000lb...
SANY SY225C LC EXCAVATOR (A63276)
SANY SY225C LC...
2005 Dynapac CT262 Sheep's Foot Compactor (A62679)
2005 Dynapac CT262...
