Harbor Freight Chop Saw
/ Harbor Freight Chop Saw #1
Deere Dude
Elite Member
Beaver Dam Wisconsin then to Hohenwald, TN
John Deere 3720
I know I should probably trash the grinder but I am kind of attached to it...
I had this 14" HF chopsaw for 12 years. I put new brushes in it 3 years ago, and yesterday I was sort of horsing it through a piece of 5/16 x 5.5 flatstock and I melted the switch.
HF doesn't sell those switches anymore, and I found I can run the saw by bypassing the switch.
I have a heavier duty chop saw but wanted to keep this one around for an emergency if the better saw takes a crap. What would you suggest for a switching operation. I wouldn't really want to just plug it into in the wall to operate it.
Safety suggests I just junk it, but...
/ Harbor Freight Chop Saw #2
You need two hands to run this saw. Usually one to hold the material, and the other to operate/turn on the saw. So the only options I see for a switch that is not in the handle, are a foot operated switch, or a knee operated switch mounted to the bench.
/ Harbor Freight Chop Saw #3
I have a cheap reciprocating saw that I bought from Princess Auto. The trigger switch quit working shortly after I bought it. Ya I know Princess Auto has a lifetime warrenty but I wanted to see if I could fix it. So I went to an electrical rebuild place and asked if they knew of a switch that could be modified to fit within the existing handle. I ended up with a switch that was very close. All I had to do was remove the part that locks the switch for continuous running. So for $17 I had what I needed to fix a $23 saw. :)
Before you give up or make something I would do the same. Go to an electrical repair place and If you get a knowledgeable person like I did you might come home with something that works.
/ Harbor Freight Chop Saw #4
I had same thing happen to my HF chop saw. Not having any luck finding a switch to fit or modify slightly, I put in a push button starter switch purchased at auto parts store. Drilled hole in front of the handle to mount the switch and now I grip handle with fingers and squeeze with palm of my hand. Works pretty good and has been this way 4 years now.
/ Harbor Freight Chop Saw #7
It doesn't even have to be hard wired in line. There cannot possibly be an easier solution.
/ Harbor Freight Chop Saw #8
Boy, is this a clever solution.:thumbsup:
/ Harbor Freight Chop Saw #9
+2 on the foot switch. rig it up on a plug and outlet so you can move it to other tools if needed like a drill press.
/ Harbor Freight Chop Saw #11
The switch on my HF cement mixer died and I just hard wired it and plug it in to make it go around.
The saw - I would do the same, I am lazy by nature :)
/ Harbor Freight Chop Saw #12
Yikes. How would you shut down quick in an emergency without letting go of the workpiece or the saw handle, or both?
/ Harbor Freight Chop Saw #14
If you got 12 years out of a HF chop saw you are ahead of the curve. Mine did 5 of intermittant use the smoked itself. The Makita I replaced it with only cost $200 and came with a nice 4.5" grinder. Ya gotta keep shopping the internet deals....
Engine knock
Engine knock
(4) Heavy-Duty Pipe Gates (A66408)
(4) Heavy-Duty...
2017 Lincoln MKC Multipurpose Vehicle (MPV), VIN # 5LMCJ2C95HUL50284 (A65563)
2017 Lincoln MKC...
Wacker Neuson HI400 Industrial Heater (A65579)
Wacker Neuson...
New/Unused Wolverine Quick Attach Coupler (A65583)
New/Unused...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
