Harbor Freight Chop Saw
/ Harbor Freight Chop Saw #1
Deere Dude
Elite Member
Beaver Dam Wisconsin then to Hohenwald, TN
John Deere 3720
I know I should probably trash the grinder but I am kind of attached to it...
I had this 14" HF chopsaw for 12 years. I put new brushes in it 3 years ago, and yesterday I was sort of horsing it through a piece of 5/16 x 5.5 flatstock and I melted the switch.
HF doesn't sell those switches anymore, and I found I can run the saw by bypassing the switch.
I have a heavier duty chop saw but wanted to keep this one around for an emergency if the better saw takes a crap. What would you suggest for a switching operation. I wouldn't really want to just plug it into in the wall to operate it.
Safety suggests I just junk it, but...
/ Harbor Freight Chop Saw #2
You need two hands to run this saw. Usually one to hold the material, and the other to operate/turn on the saw. So the only options I see for a switch that is not in the handle, are a foot operated switch, or a knee operated switch mounted to the bench.
/ Harbor Freight Chop Saw #3
I have a cheap reciprocating saw that I bought from Princess Auto. The trigger switch quit working shortly after I bought it. Ya I know Princess Auto has a lifetime warrenty but I wanted to see if I could fix it. So I went to an electrical rebuild place and asked if they knew of a switch that could be modified to fit within the existing handle. I ended up with a switch that was very close. All I had to do was remove the part that locks the switch for continuous running. So for $17 I had what I needed to fix a $23 saw. :)
Before you give up or make something I would do the same. Go to an electrical repair place and If you get a knowledgeable person like I did you might come home with something that works.
/ Harbor Freight Chop Saw #4
I had same thing happen to my HF chop saw. Not having any luck finding a switch to fit or modify slightly, I put in a push button starter switch purchased at auto parts store. Drilled hole in front of the handle to mount the switch and now I grip handle with fingers and squeeze with palm of my hand. Works pretty good and has been this way 4 years now.
/ Harbor Freight Chop Saw #7
It doesn't even have to be hard wired in line. There cannot possibly be an easier solution.
/ Harbor Freight Chop Saw #8
Boy, is this a clever solution.:thumbsup:
/ Harbor Freight Chop Saw #9
+2 on the foot switch. rig it up on a plug and outlet so you can move it to other tools if needed like a drill press.
/ Harbor Freight Chop Saw #11
The switch on my HF cement mixer died and I just hard wired it and plug it in to make it go around.
The saw - I would do the same, I am lazy by nature :)
/ Harbor Freight Chop Saw #12
Yikes. How would you shut down quick in an emergency without letting go of the workpiece or the saw handle, or both?
/ Harbor Freight Chop Saw #14
If you got 12 years out of a HF chop saw you are ahead of the curve. Mine did 5 of intermittant use the smoked itself. The Makita I replaced it with only cost $200 and came with a nice 4.5" grinder. Ya gotta keep shopping the internet deals....
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
KBH Tender Trailer (A63118)
KBH Tender Trailer...
LOOK! (A63116)
LOOK! (A63116)
2020 Deere 544L (A60462)
2020 Deere 544L...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
Arrow Quip EF10 Top Bow No Sides (A64047)
Arrow Quip EF10...
