hand throttle problem
/ hand throttle problem #1
fish_wisperer
Banned
east of dallas
mahindra 4500 2wd
my father in laws ym165 throttle loosens itsself during normal operation, ive tried making more throtthr friction but the lock nut loosend when i move thr throttle bach and forth any tips? we need a constant hand throtthe
/ hand throttle problem #2
You can replace the original friction washer and the problem is solved. You can also 'dimple' the washer faces with a punch and hammer and extend the life even further.
Mark
/ hand throttle problem #3
thanks Mark
I've had the same problem with my 2000 since I got it.
/ hand throttle problem #5
Mark,
Is the friction washer you refer to located in the throttle linkage. I have a 3110d with the same problem.
Thanks,
Jim
/ hand throttle problem #6
jab said:
Mark,
Thanks,
Jim
Jim,
Yes. If you follow the hand throttle down to the large plate that actuates the injector pump link...that plate + friction disk, two washers and two nuts make the complete assembly. One nut is to apply desired pressure and the other acts as the stop nut. The quick and dirty fix is dimpling but the friction disk runs less than $2.
Mark
/ hand throttle problem #7
Mark, Thanks very much for the info.
Jim
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
CAT 963C Cab (A68134)
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2023 CATERPILLAR 239D3 SKID STEER (A65056)
2023 CATERPILLAR...
2014 MAC FLAMELESS HEATER  (INOPERABLE) (A68842)
2014 MAC FLAMELESS...
