hand throttle problem
/ hand throttle problem #1
fish_wisperer
Banned
east of dallas
mahindra 4500 2wd
my father in laws ym165 throttle loosens itsself during normal operation, ive tried making more throtthr friction but the lock nut loosend when i move thr throttle bach and forth any tips? we need a constant hand throtthe
/ hand throttle problem #2
You can replace the original friction washer and the problem is solved. You can also 'dimple' the washer faces with a punch and hammer and extend the life even further.
Mark
/ hand throttle problem #3
thanks Mark
I've had the same problem with my 2000 since I got it.
/ hand throttle problem #5
Mark,
Is the friction washer you refer to located in the throttle linkage. I have a 3110d with the same problem.
Thanks,
Jim
/ hand throttle problem #6
jab said:
Mark,
Thanks,
Jim
Jim,
Yes. If you follow the hand throttle down to the large plate that actuates the injector pump link...that plate + friction disk, two washers and two nuts make the complete assembly. One nut is to apply desired pressure and the other acts as the stop nut. The quick and dirty fix is dimpling but the friction disk runs less than $2.
Mark
/ hand throttle problem #7
Mark, Thanks very much for the info.
Jim
2017 CATERPILLAR 335FL CR EXCAVATOR (A65056)
2017 CATERPILLAR...
2021 Chevrolet Equinox SUV (A66738)
2021 Chevrolet...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
