hand throttle problem
/ hand throttle problem #1
fish_wisperer
Banned
east of dallas
mahindra 4500 2wd
my father in laws ym165 throttle loosens itsself during normal operation, ive tried making more throtthr friction but the lock nut loosend when i move thr throttle bach and forth any tips? we need a constant hand throtthe
/ hand throttle problem #2
You can replace the original friction washer and the problem is solved. You can also 'dimple' the washer faces with a punch and hammer and extend the life even further.
Mark
/ hand throttle problem #3
thanks Mark
I've had the same problem with my 2000 since I got it.
/ hand throttle problem #5
Mark,
Is the friction washer you refer to located in the throttle linkage. I have a 3110d with the same problem.
Thanks,
Jim
/ hand throttle problem #6
jab said:
Mark,
Thanks,
Jim
Jim,
Yes. If you follow the hand throttle down to the large plate that actuates the injector pump link...that plate + friction disk, two washers and two nuts make the complete assembly. One nut is to apply desired pressure and the other acts as the stop nut. The quick and dirty fix is dimpling but the friction disk runs less than $2.
Mark
/ hand throttle problem #7
Mark, Thanks very much for the info.
Jim
55 GALLON BARREL TOTE/ OVERHEAD CREEPER (A67714)
55 GALLON BARREL...
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2015 KEYSTONE BULLET CAMPER (A67714)
2015 KEYSTONE...
2007 VERMEER T755 COMMANDER III TRENCHER (A67714)
2007 VERMEER T755...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
