Guestimate propane use this winter?
/ Guestimate propane use this winter? #1
rogdan
West Virginia
Farmtrac 360 DTC TLB
We plan to move into our new home next month right at the beginning of the heating season in northern West Virginia. We are changing from natural gas to propane FA in the new place. I am having trouble getting a bulk propane supplier and am getting down to the wire. So I was trying to guess what my propane use would be this winter As I thought of just getting some 100lb tanks to get by this winter, is this even worth trying? For comparison the new place is 2000 sq ft with 2x6 insulated walls compared to the old place at 1300 sq ft poorly insulated. In the old place I used as much as 12 MCF of natural gas in the coldest month with the FA system. I feel that no more heat would be required in the new place with the much better insulation. I am new to propane anyone care to give some opinions? Thanks
/ Guestimate propane use this winter? #2
We are just over 2100 Sq. ft and 2x6 walls. We have electric heat pump and propane. Also use propane for water. I believe we usually go through around 500 - 600 gallons per year - but I can't swear to it. I know last year we purchased 647 gallons from our existing propane provider but we didn't start using them until 12/31 and had to fill the tank completely. So the 500 - 600 probably isn't too far off.
/ Guestimate propane use this winter? #3
I'm going to say between 600-800 gallons a winter. My use here in WNY is about 400 gallons but my whole house is propane and the house is heated by a pellet stove. If they corner you go heavy and say 800 gallons. You'll be close.
Congrats by the way.
Thanks for the replies guys, I think I could pull off the 100 lb tank idea for this winter if I have to. I don't want to do this but I am not getting good response from the local suppliers.
Another reason for the tanks is that I may have an outdoor wood boiler put in next year and plumbed to the furnace and HW tank.
/ Guestimate propane use this winter? #5
Hmm, I'm puzzled about the other responses. I use much more propane than stated by others. Maybe, its because we also have a propane water heater ?
I typically use 1,500 to 1,600 gallons of propane per year for FA heating and hotwater. My neighbor uses closer to 2,000 gallons. He uses propane for heating, hot water, and clothes dryer.
/ Guestimate propane use this winter? #6
Oh, forgot to mention. Both homes are about 2,200 sq ft with cathedral ceiling in great room. Homes built in 1994. Furnace is 80% efficiency.
/ Guestimate propane use this winter? #7
Will the 100 gallon tanks vaporize enough liquid propane in cold weather to feed the furnace ? The surface are of the liquid in the tank controls how much propane gas can be drawn from the tank.
I think it might also be a problem/hassle refilling tanks every week or so during the coldest part of winter.
Ben
The furnace is not in yet but I think we are over 90% on effeciency. We will only be heating with propane with everything else being electric in the home.
I haven't thought of that as I am unaware of the characteristics of propane. I don't look forward to lugging thoose tanks around /forums/images/graemlins/crazy.gif
Ideally I wanted to do an underground tank but that requires that I own and install the tank but the local suppliers only want to fill their own. Catch 22 /forums/images/graemlins/confused.gif
/ Guestimate propane use this winter? #10
Yes, common catch 22 on the self owned tank.
How many BTU is your furnace ? Propane has about 91,000 BTU per gallon of liquid. Perhaps this would help in your figuring ?
I live in a similiar climate here in east central KY. My house is about 1600 sq ft and I burn about 600-700 gallons per year.
Ben
/ Guestimate propane use this winter? #11
W/ the costs of heating.. I'd be looking at that 75 acres of woods and a nice woodstove.
/ Guestimate propane use this winter? #12
We ordered 500 gallons of propane for last winter and had enough left over to cook on the stove with all summer, still have some left.
We have propane forced air heat in about a 2000 sq foot ranch.
We also have an outdoor woodburning furnace, I used that a lot last winter until I ran out of wood, so that helps keep our propane use down. We also had a home energy audit done with one of those blower doors to identify air leaks, hopefully I have a lot of those sealed up for this winter.
/ Guestimate propane use this winter? #13
I agree with Mrwurm. We use about the same amount of propane, 1500-1600 gallons, and usually keep the heat VERY low, about 68 at the most. We have a four year old house that is very well insulated. Our hot water heaters use little propane as they are the instant ones. Our dryer is electric.
/ Guestimate propane use this winter? #14
I live in western NY, 3600sq ft house and use propane for heat, hot water, dryer and cook top. We go through about 1400 gallons per year. The house is 2 years old, 2x6 constructed and has a high eff. furnace that we keep around 70-72 degrees. We also have a programmable thermostat and both of us work so we keep the house cooler when we're not there.
Doug
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2011 Freightliner B2 School Bus (A61568)
2011 Freightliner...
2011 Porsche Panamera Sedan, (A61574)
2011 Porsche...
