Growing potatoes
/ Growing potatoes #1
sros990
West Virginia
JD 990
What tractor implements are used to plant, hill and dig potatoes in a large home garden?
Thanks,
Steve
/ Growing potatoes #2
Friend of mine uses a Troy tiller with a hiller attachment both also available as tractor attachments.
/ Growing potatoes #3
What Pineridge said... You might want to look at the tiller mod page down this forum screen.
Dad used the backhoe to dig potatoes during a drought one year when the ground was hard as a rock.
/ Growing potatoes #4
I harvested about 4 bushel last year from my garden. I used a Middle Buster to dig them up. It did an excellent job; very few damaged potatoes (see picture).
John
/ Growing potatoes #5
We put 200lbs in the ground a couple weeks ago.. the ground was plowed last fall.. hit it w/ the disk this spring.. then tilled to fluff the dirt.. then used the disc hiller to make the hills.
We have one man dropping the potatoe cuts.. another follows behind & pushes it into the dirt w/ a stick.
And like others have said.. use the middle buster(potatoe plow).. to harvest.
Mmmm fresh potatoes & potroast.. I'm getting hungry!
/ Growing potatoes #6
Hey John those are some great looking spuds. Do you do anything special to store them?
/ Growing potatoes #7
If you're talking home garden, I'd look at a Mantis "Little Wonder" tiller/cultivator for weeding etc. I till with my 455 and then cultivate with my Mantis. The loose dirt is then raked up ti "hill" my rows.
That middle buster harvest method sounds pretty cool!
/ Growing potatoes #8
Mike, I store my potatoes in my lower garage. My property is on a hillside so when I built my home I used prestressed concrete for the floor of my main garage. Underneath my main garage I have a second garage that is mostly underground. As a result of the garage being underground, the inside temperature rarely gets below freezing. The outside temperature has to be at or below zero for several days before garage temperature goes below freezing. It's an ideal place to store the potatoes. We just finished the last of the potatoes last week.
BTW, that's not me in the picture. It's my oldest son. I'm a lot older and fatter than him! /forums/images/graemlins/blush.gif
John
1/2" Quick Attach Blank Plate (A66408)
1/2" Quick Attach...
2022 EZ-GO ELITE...
2013 LAY FLAT REEL TRAILER (A65643)
2013 LAY FLAT REEL...
2001 Ford F-550 (A66408)
2001 Ford F-550...
KUBOTA SVL97-2 (A65643)
KUBOTA SVL97-2...
Volvo 10ft Loader Rake Attachment (A64553)
Volvo 10ft Loader...
