Ground clamps.
/ Ground clamps. #11
Troven, I have never grounded both pieces, I believe that once you make the smallest of a weld, you have ajoined the two anywho. Today I didn't ground anything...I simply grounded to the meatl table and the work pieces touched it...
/ Ground clamps. #12
I use something similar to this... as my brass ground clamp spring usually doesn't clamp very good, I keep a pair of vice grips handy to increase the pressure on the clamp. I probably have a couple of new ones in the box over on the shelf, but am too cheap to throw away one that I can still make work.
David from jax
/ Ground clamps. #13
What Artisan said. If you have a situation where it becomes a problem, just make sure you ground the piece that you want to start your arc on. After you start, you are good to go.
2020 DRAGON ESP...
High Accuracy Meter Fuel Pump (A61166)
High Accuracy...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
1995 6ft. Wee Willie S/A Utility Trailer (A59231)
1995 6ft. Wee...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
KJ K4230G 42'x30' Metal Storage Shed (A60463)
KJ K4230G 42'x30'...
