Grinding / Sharpening Pros Here?
/ Grinding / Sharpening Pros Here? #21
A bench grinder? I dunno, I bet ya a 10' bench grinder would "hollow"
out a .25" wide chipper blade held at a 45* angle. :) Thus the grind
would be concave instead of flat.
so what problem would that cause, the concave would be so light I could not see "harm" it could cause, If not use a cup wheel and make a guide like I suggested earlier with a piece of angle iron or two pieces of flat bolted together, for a guide, the guide could be made out of wood as far as that goes.
if you want a holder for the blade bolt the bench grinder to a table and make the guide so it slides across the table, many ways to do this and do it fairly cheaply,
here is a guy who made a small wood holder and uses his drill press with a grinder wheel in it,
Advice appreciated on sharpening Chipper blades
here is a $700 dollar grinder that is not much more than a bench grinder and a cup wheel and a guide like I sugested,
New Page 1
here is a steel holder for mounting a chipper blade so it can be ground,
http://www.dippert.com.au/images/chipper01.jpg
here is probly the easest and simplest set up with a small ledge all would be ground the same, using a bench grinder and a wood block for a guide,
sharpening chipper blades - Page 4 - Arbtalk.co.uk | Discussion Forum for Arborists
2021 Deere 331G (A53317)
2021 Deere 331G...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
2016 Ram 4500 Crew Cab Landscape Dump Truck (A59230)
2016 Ram 4500 Crew...
2012 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2012 HEIL TRAILER...
KUBOTA M6S-111 TRACTOR (A59823)
KUBOTA M6S-111...
