Grinding / Sharpening Pros Here?
/ Grinding / Sharpening Pros Here? #21
A bench grinder? I dunno, I bet ya a 10' bench grinder would "hollow"
out a .25" wide chipper blade held at a 45* angle. :) Thus the grind
would be concave instead of flat.
so what problem would that cause, the concave would be so light I could not see "harm" it could cause, If not use a cup wheel and make a guide like I suggested earlier with a piece of angle iron or two pieces of flat bolted together, for a guide, the guide could be made out of wood as far as that goes.
if you want a holder for the blade bolt the bench grinder to a table and make the guide so it slides across the table, many ways to do this and do it fairly cheaply,
here is a guy who made a small wood holder and uses his drill press with a grinder wheel in it,
Advice appreciated on sharpening Chipper blades
here is a $700 dollar grinder that is not much more than a bench grinder and a cup wheel and a guide like I sugested,
New Page 1
here is a steel holder for mounting a chipper blade so it can be ground,
http://www.dippert.com.au/images/chipper01.jpg
here is probly the easest and simplest set up with a small ledge all would be ground the same, using a bench grinder and a wood block for a guide,
sharpening chipper blades - Page 4 - Arbtalk.co.uk | Discussion Forum for Arborists
Diesel Engine Oil Tank (A61573)
Diesel Engine Oil...
(8) John Deere Tractor Weights (A64119)
(8) John Deere...
30" X 11' ADS DRAINAGE PIPE (A64281)
30" X 11' ADS...
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
1991 BMY 6x6 Wrecker (M936A2) (A62613)
1991 BMY 6x6...
2023 RIPPA R360 EXCAVATOR (A64279)
2023 RIPPA R360...
