Grinding / Sharpening Pros Here?
/ Grinding / Sharpening Pros Here? #1
Artisan
Monrovia, California
Kubota BX25
Gents I want to buy a machine that will quickly and easily put an edge on
my blades. The blades are quite simple and the manufacturer calls for a
45 Degree Angle on the blades. I would like a machine where I can simply
bolt them down and do the pass's as required and end up w/ a sharp
blade. I care not to try to hold a perfect angle and do it free hand...
Am I dreaming or is there a simple machine out there I need to look for?
The blades are about 3.125" long x .250 thick by about 2.00 Wide.
Here is a picture of the blades.
/ Grinding / Sharpening Pros Here? #2
Just a rambling thought from a jack-of-all-trades, master of none. Using a grinder will cause heat-temper problems unless you have a coolant spray.
/ Grinding / Sharpening Pros Here? #4
Disk sander with a miter gauge?
I sharpen mower blades on a belt/ disk sander with great results.
/ Grinding / Sharpening Pros Here? #5
If you want it perfect, build a jig to hold them and your grinder at exact angle. Dont get in a hurry and overheat them, it doesnt have to turn the steel blue if you take it slow. Sharpen often so you dont need to take a lot off at a time, kind of like sharpening a chain saw, keep it sharp and only need to hit it a couple licks to touch up the edge.
That Makita may be the ticket...
I just watched [ame="http://www.youtube.com/watch?v=xIozLT4T6KM&feature=relmfu"]THIS[/ame] and it looks like I might be able
to lay a thin strip of .25" material in there then lay in all 4 blades at one
time, THAT would produce all blades to the same dimension and WEIGHT.
/ Grinding / Sharpening Pros Here? #8
If you know any one with a bridgeport (mill) that would be the best way. You could take off the exact amount from each blade and have the exact same angle.After they were sharpened the first time you could touch them up with a belt sander.
Bill
Bill
I am somewhat fluent in "Horizontal Mill" but have no where to plant one...
Some day perhaps...till then that Makita is looking nice...
/ Grinding / Sharpening Pros Here? #11
norther tool is having a sale on their low speed water sharperner its ~110.oo and free shipping the model is the 8'' wet sharpener, has a speed of 120 rpm.
item# is 338420-1213
it can sharpen up to 1/2-4'' long
/ Grinding / Sharpening Pros Here? #12
just a custom guide on a bench grinder should do the trick,
basicily a flat plate with a ledge on the bottom of it and set at the proper angle, and pass the knife across the face of the stone, and pick up the second and so on and then repeat until you have them back to where you want them,
now some depends on what here used for,
if there chipper blades then the bench grinder should be good enough, but if they need to be near perfect then your planer knife sharpener,
this is a dry type grinder, G2790 Universal Knife Grinder
/ Grinding / Sharpening Pros Here? #13
An old surface grinder would be good. Every so often they come up on Craig's list.
/ Grinding / Sharpening Pros Here? #14
I own the Makita grinder you are looking at. The wheel that comes with it is so fine, it is more of a honing than a grinding wheel. I need to get and try the coarse wheel sometime, but I find the stock wheel to be painfully slow. I use it for WW tools like chisels, plane blades, and jointer/planer blades. And even on those, I find it painfully slow. On tractor type stuff? Fuggedaboudit. Maybe the coarse wheel will work, but the stock one will be hopeless.
/ Grinding / Sharpening Pros Here? #16
bench grinder!
it has a electrical motor in the center. and generally 2 different types of wheels. (one on each side of the motor) each side normally has some sort of generic adjust plate, to manual hold stuff at certain angles as you grind things. and allows you to move the blade back and forth across the grinding wheel. allowing you to hit different spots. so you do not over heat the metal as you grind it.
generally some "vice grips" would be suggested, so you can set and grip down on the vise grips. and then have easy handles to move the metal. without getting your hands in the way of your sight, and keep your fingers away from the hot metal.
mower blades do no need a razor blade sharpness to them. a butter knife sharp if not more blunted is what i have always understood as correct way to sharpen blades.
/ Grinding / Sharpening Pros Here? #17
Magna Matic 9000
I use it on all my stuff and it is fast. I mow commercially and its the only way to go
/ Grinding / Sharpening Pros Here? #18
I use a linisher for all types of sharpening tasks - knives, chisels, mower cutters, etc.
A medium grit linishing belt has a number of advantages over a bench-grinder wheel. Principally, it runs relatively cool and there is far less chance of overheating the metal and destroying its temper.
Also, the belt is a lot wider and this does away with the need to skillfully move the workpiece at a constant angle.
The linisher that I use has an adjustable 'rest' that can be set at the desired grinding angle.
(When I'm sharpening knives and chisels, the linisher is only used to grind the primary angle - I hone the secondary (cutting) bevel on a fine oil or waterstone.
With your mower cutters a medium grit abrasive belt would produce a pretty good result, without much effort.
It's a very handy tool for all sorts of metal projects.
Ed
A bench grinder? I dunno, I bet ya a 10' bench grinder would "hollow"
out a .25" wide chipper blade held at a 45* angle. :) Thus the grind
would be concave instead of flat.
A "linisher" would be nice to have.
The Magna Matic looks good for mower blades.
The Makita stills looks good. I found one for sale and
the folks wrote me back telling me that were busy "haying" .
So I sit.
That NorthernTool Wet Unit sure is priced right... I did the calcs and splitting
hairs indeed it is but a 10" grinder cuts a .0031 deep divot into a .250" blade
held at a 45* angle to the wheels quadrant.
That Grizzy unit is priced liek a used Makita but new and the same design!
Verrrrrrry In-ter-est-ting (in my best Arte Johnson voice)
1985 Mack RW713 Superliner Tri-Axle Heavy Haul Truck, VIN # 1M2AY11Y6FM001206 (A61165)
1985 Mack RW713...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
2001 KUBOTA R520 BACKHOE (A62129)
2001 KUBOTA R520...
TAKEUCHI-VIRNIG TRRG72 - 72" HYD ROOT RAKE GRAPPLE (A62129)
TAKEUCHI-VIRNIG...
2020 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A61567)
2020 Toro...
