grinding noise while turning
/ grinding noise while turning #1
marcin
Texas
john deere 5205, 1968 john deere 5020
Another 5020 issue.
Following recent engine rebuild and hydraulic pump overhaul, I had some leaking brake lines. I decided to rebuild all of them as well as the brake valve, differential valve, pressure control valve and steering cylinders as all were badly leaking. I noticed a new problem after running the tractor now - while turning there is a grinding noise (sounds like its coming from differential or maybe transmission) What could this be? I really don't want to use the tractor before this is resolved as I am afraid of messing up something else. Thanks to all.
/ grinding noise while turning #3
Could your rear axle lock somehow be hung up and not be fully disengaged? You'd hear nothing going straight ahead.
Rear axle lock - how would I know if it is engaged?
I also noticed that the brakes are quite bumpy when I push them and the differential is very hard to push down? Do I need to release air from the system or does it happen by itself?
I am not sure if these are related, but before I rebuilt the valves everything worked well and there were no clunking noises coming from the back while turning. Thanks again.
Can someone please help me with this?
/ grinding noise while turning #6
Never rebuilt that type of diff or pump. Certainly sounds like binding of the rear end/diff. Could there have been a shaft or pin/key that went in sideways or backwards on the reassembly? Did anything require a press to be seated properly? maybe there is just a slight tolerance issue that is causing this hiccup.
If you could jack up one side of the rear, place it in neutral and then secure the machine so that it could not move forward or back, you may be able to turn the lifted tire to confirm the diff is not locked up.
/ grinding noise while turning #7
If you suspect diff lock is engaged loosen fitting on line(parts key 6) if no oil comes out under pressure with engine running then diff lock isn't the problem. My guess to grinding is diff pinion shafts(2nd photo) are spinning in housing or pinion gears have failed.
/ grinding noise while turning #8
RP1344_________UN01JAN94.gifSince you mention the differential lock valve is hard to push, I suspect maybe something inside the valve is not assembled properly or the linkage going to brake pedals may be binding.
Everything worked fine before I took the valves apart.
Something seems to be wrong with the diff valve, as it is very hard to push and release and the small line leading to it is shaking and gets hot really quickly. The problem is not there immediately after start up, but happens after a few minutes - almost seems like the pressure needs to build up? I took the diff valve apart again and everything seems put together appropriately. I removed 2 extra shims I added, but I do not think that is the problem. The only thing that I did not put together as before were the spring and stop (parts 4, 5) leading to the brake accumulator as they were broken and needed to be ordered - I am not sure if these could be the cause? I will put these back together tomorrow and retry. Any further ideas in the interim? Thank you.
I added parts 4,5 in the diagram above and problem appears solved. No more shaking and heating of the differential line and nor more clunking during turns.
The clunking still happens when the diff is on during turns - is that normal? Thank you again.
/ grinding noise while turning #11
Yes turning with diff lock engaged defeats the purpose of pinion gears/shafts in diff.
/ grinding noise while turning #12
I seldom use differential lock on my equipment except for rare occasions. Needing it indicates that it is too wet and I should wait for the ground to dry out more or that I am over working the tractor with too high of a draft load. It is helpful for small slick spots on occasions though. If you lock up the rear wheels you should expect to go straight only.
I have been using it quite a bit while chisel plowing. I hope I had not messed anything up?
The tractor has 140hp and the chisel plow has only 11 shanks, I thought it should pull it without too much trouble.
Perhaps the tires are too worn? How do I measure the wear of rear tractor tires - can't find a method anywhere online.
/ grinding noise while turning #14
I've utilized the diff lock when plowing many acres with my 4255 with no known ill affects BUT I always disengage DL when turning. IMHO there's not a lot of difference in traction on worn vs new tires. Some tractor pullers prefer worn tires. Look at the new style short cleat tires built specifically for tractor pulling.
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
AIRMAN PDS185S PORTABLE AIR COMPRESSOR (A65056)
AIRMAN PDS185S...
AGT QA Pallet Forks (A64912)
AGT QA Pallet...
3pt Ditcher (A64912)
2015 John Deere 323E Compact Track Loader Skid Steer (A66734)
2015 John Deere...
