grillo 107d
/ grillo 107d #1
223coyote
oshkosh wi.
john deere 300
does anyone have one and how do they like it . I have an acre of land I would like to till . and would probably get a flail mower and a blade for snow , does any one have expiriences with these accessories , the soil I plan on tilling is clay sod.
jim
/ grillo 107d #2
Hi! I have a Grillo 107d for now over five years. Run fine. At first I had some clay soil. With tiller tines in soil look for push the tractor. BCS and Grillo are too light. I add weight in wheels 80 lb . Now a lot better.
For flail mower . I dont know. For me I prefer rotary mower. More easy to keep sharp. Less expensive to buy and repair. And often make a better job.
For snow with a blade you need a lot of weight in wheels .
I adapt a TORO front end snowblower. Run very well. Can blow snow over 30 ft. You cannot adapt this on BCS because wrong rotation. Good luck! Oldmech grilosou.jpg
/ grillo 107d
I wonder what would be faster and till better a tiller or a bersa rotary plow . does anyone have a trailer for theirs for riding on and transporting the tiller , gas, chainsaw , lunch etc. ?
/ grillo 107d #4
Welcome to the forum. There is a ton of good info here.
I don't know if you can have a trailer and transport the tiller. I have the front mount cart on a 107d and love it. Depending on where your driving I assume a ride on could be a rough ride.
/ grillo 107d #5
Welcome to the group!
I just got home from the MOSES Organic conference in La Crosse. Did you go?
The Berta rotary plow is far superior to a rototiller for breaking ground. It cuts a 10" path, but will till deeper in that one pass than a tiller will in three passes. In doing so, it's far gentler on the soil and will not make a hardpan like a tiller can if misused. It will also do a better job of burying the sod than a tiller. I think it's one of the most useful attachments you can own if you have a large garden.
You can buy a curved coupler that will allow you to pull a trailer with the tiller attached. I don't know if you can use the same quick coupler with the plow attached.
/ grillo 107d
I wish I would have known about the moses conference.
I plan on buying a 107d with the Bertha rotary plow .you are a dealer in Wisconsin aren't you . I have some land by hillsborro wis . Could you find out if I could use a trailer with the plow.
Jim
/ grillo 107d #7
Hillsboro is fairly close to me, closer than OshKosh, anyway. I am currently the only dealer in Wisconsin, but that could change any day now.
I just emailed Joel. He just got back to Kentucky from MOSES, so he may take awhile to respond. As soon as I know, you'll know.
/ grillo 107d #8
Bought a 107D last year, so far I've only used the tiller attachment and its a huge improvement for me. I mainly use it for raised beds and weed control once things are growing too thick or tall for the 40 hp tractor. Never had a good tiller like a Grillo or BCS, it blows away the common box store machine by far. I want to get the berta plow next. I guess I do at least 2 acres with the tiller, probably more. I don't break ground much with it since I do have a 6' pto tiller, but I have tilled some really tough rocky and hard chert like stuff and it gets the job done. The 107D lets me pack in my rows tighter, I do have a nice 4x4 tractor with all the attachments, but the 107D still saw lots of use last year. Trying to avoid all chem weed killers so, I use the 107d to lightly cultivate things. Love how it is so easy to turn and control in tight spots, the tiller is great for small seeds, makes a very nice and fine seed bed. Love the tine speed.
/ grillo 107d #10
I use this units commercially, but my next 107d will be a diesel. The diesel 8hp burns fuel at .25 gph at WOT. My Honda is closer to .65
Sent from my iPad using TractorByNet
/ grillo 107d #11
Joel says the curved coupler will not work with the rotary plow. You could disconnect it, protect the pto socket with a cover, and haul the plow in the trailer, though.
/ grillo 107d
Do I need weight in the tires if my main use is tilling. I was reading somewhere that they recommended it.
Jim.
/ grillo 107d #13
Not really. Mostly, you need weight for unpowered equipment like moldboard plows and ridgers. You may want weight with a trailer, but you add weight by riding it.
/ grillo 107d
I ordered a 107d with a tiller and a trailer. Now I hope the weather warms up soon.
Jim
/ grillo 107d #15
Congrats. When you have some time post of photos of your setup.
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
2004 CATERPILLAR 242 SKID STEER (A64279)
2004 CATERPILLAR...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
PAIR OF TRACTOR TIRES AND RIMS (A63569)
PAIR OF TRACTOR...
SKIDDED PLAIN/WASTE WATER TANK (A63569)
SKIDDED...
John Deere 5045E for sale
John Deere 5045E...
