grill repair
/ grill repair #1
almaryholm
Lake City,MN
TYM T450 w/ loader...had NH TC30
Noticed the plastic(?) nose of my tractor ( TYM T450) is cracked just above latch ...any ideas how to repair ???
/ grill repair #2
I had to replace one on a T353 HST after poking some brush through it. I believe the grill was less than $30 and arrived in less than a week from my local dealer and took less than 10 minutes to replace. I added a metal guard made out of 1/8" 2X2 angle iron and expanded metal to the factory guard. By cutting the angel iron in two places and bending it I put a curve in the expanded metal which made it quite stiff and rigid. This works well to protect the plastic grill. I'll try to add a picture this weekend.
/ grill repair #3
If the hood itself is cracked try JB Weld compound. It can be sanded down flush and painted. Be sure to drill a hole in the end of the crack as a stress reliever and fill the hole as well.
/ grill repair #4
I have repaired many plastic items including my tractor grill, trailer fender flares and portable gas cans using a hot glue gun.
The trick is to mix some hot glue in with the plastic part being repaired.
Heck I even repaired Cessna plastic wing tips that way.
/ grill repair #5
Drill stop, fiberglass from the rear, fill crack, sand, blend paint
/ grill repair
Talked to dealer today and wants $158.96 for replacement ?!!...guess will be a repair job...funny, there seems to be a double layer of plastic there as not cracked all the way through ( more splintered )...maybe inject some kind of plastic glue and clamp (?) thanks to all...al
/ grill repair #7
Let us know how the repair turns out.
/ grill repair #8
Is it plastic or fiber glass?
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
(2) HEADACHE RACKS (A63569)
(2) HEADACHE RACKS...
2020 FORD RANGER(INOPERABLE) (A63569)
2020 FORD...
2005 BOBCAT 323J EXCAVATOR (A64279)
2005 BOBCAT 323J...
2020 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A61573)
2020 Autocar...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
