Grid-tied solar
/ Grid-tied solar
Results for May 2015.
Best May to date. More in line with the updated NREL models too but well above previous May outputs. Likely because we had so little rain this May, less cloudy weather.
*********************************** Model Prediction ***********************************************
OLD
_______388____412____509_____374____353____308____ 341___383____394____369____283____331____4,447
NEW Waterville, ME
_______273____322____491_____449____417____375____ 438___542____443____408____350____319____4,827
NEW Portland, ME
_______453____486____523_____452____448____409____ 444___464____466____461____351____368____5,325
GENERATION
Year___Jan____Feb____Mar____Apr_____May____Jun____ Jul____Aug____Sep____Oct____Nov____Dec____Total
2012____NA____NA_____NA____NA_____NA_____NA_____NA ___461_____481____378____400____297____NA
2013____440___375____462____487_____375____379____ 377___470_____476____453____414____278____4,986
2014____360___446____577____525_____361____390____ 395___453_____489____380____295____299____4,970
2015____431___456____612____473_____440
Values are AC kilowatt hours.
Model source: NREL PVWatts Calculator
/ Grid-tied solar #982
I'm in! 21 x 305 LG neon high performance panels. Solar edge system. More to follow. HS
/ Grid-tied solar #985
The closest I've come was with enphase microinverters... still couldn't pencil out the cost for my 360 kWh per month.
Maybe Solaredge is more competitive pricewise?
/ Grid-tied solar #986
/ Grid-tied solar #987
What kind of deal are you getting with the Power Company as far as buy-back etc?
/ Grid-tied solar #988
My power company is a small coop, and has net metering, so overages roll meter back, without net metering I don't think would have done this, plus I have a roof orientation of 185 degrees true and 30 degrees declination over a garage area, perfect for my latitude here in Texas. HS
/ Grid-tied solar #989
Did you plan the garage that way, or a happy accident?
/ Grid-tied solar #990
You have to have connection agreement in hand before you spend your money.
/ Grid-tied solar #992
I've been looking into solaredge for some time now
I think it's far superior and safer than anything else
just waiting on a new roof before putting the cost into the solar
/ Grid-tied solar #993
I'm in hill country and about 1/3 of installs are ground mounted on hillsides... easy to access no issues down the line when it comes to reroof...
/ Grid-tied solar #995
I am thinking about solar too. Can you say how much was the hardware and how much was the labor?
Our system is 24 kW DC peak or about 34000-36000 kWh/year in our location. We did all work DIY. Total hardware cost was about 54000. It took about six weeks to build mostly due to waiting for the concrete footings to cure. I estimate it took about 10 days of actual work of two people. The system is ground based about 1000 ft from point of connection. Since we are close to a substation our voltage is very close to upper tolerance limit. That required 1000 ft of a cable to handle 120 A with maximum 2V voltage drop. What I mean by all that is that the underlying structure, cable etc added a lot of the expense. The panels, inverters, multidrop cable, racking and all associated hardware (such as panel clamps, stainless steel screws, grounding lugs etc) was 44000.
If you mount your panels on a roof you can save at least 15% of the expense. We used microinverters that are also more expensive than single large inverter.
When we decided to install PV I knew nothing about that. I thought it would be much more involved process but I found it to be way simpler than expected. It is definitely DIY doable.
We bought panels, racking, inverters and all associated hardware at Civic Solar. Since we bought everything there (and I suppose because we bought it close to the end of the year) we got about 10% discount from published retail price.
/ Grid-tied solar #996
Our system is 24 kW DC peak or about 34000-36000 kWh/year in our location. We did all work DIY. Total hardware cost was about 54000. It took about six weeks to build mostly due to waiting for the concrete footings to cure. I estimate it took about 10 days of actual work of two people. The system is ground based about 1000 ft from point of connection. Since we are close to a substation our voltage is very close to upper tolerance limit. That required 1000 ft of a cable to handle 120 A with maximum 2V voltage drop. What I mean by all that is that the underlying structure, cable etc added a lot of the expense. The panels, inverters, multidrop cable, racking and all associated hardware (such as panel clamps, stainless steel screws, grounding lugs etc) was 44000. If you mount your panels on a roof you can save at least 15% of the expense. We used microinverters that are also more expensive than single large inverter. When we decided to install PV I knew nothing about that. I thought it would be much more involved process but I found it to be way simpler than expected. It is definitely DIY doable. We bought panels, racking, inverters and all associated hardware at Civic Solar. Since we bought everything there (and I suppose because we bought it close to the end of the year) we got about 10% discount from published retail price.
With a system that big the efficiencies in micro inverter system vs a SolarEdge solution might pay to switch from micro inverters. The extra power you would harvest over a 25 year period could be gigantic. HS
/ Grid-tied solar #997
Actually the gain would be marginal at best. The difference in efficiency between large inverter and microinverters is very small if any. If you include loss on wiring and connections the overall efficiency is about the same. I would have to buy three inverters because my system consists from three separate banks of panels. That would cost upward of 10000 USD. Only motivation to use single inverter for each bank would be the ability of "island" operation during power outages.
/ Grid-tied solar #998
Daimler starts selling home/commercial battery packs in September, having been targeting the market since 2009 and having some significant (including utility scale) installations in real-world use for some time. These are similar to their Merc' EV car batteries, tweaked. Installed cost is said to be similar to Tesla's powerwall, so still not feasible on a cost basis for most.
/ Grid-tied solar #999
Interesting for emergency power if they are located in place you can sacrifice or risk in a fire, but to hold enough power for nighttime unrestricted use, NO. HS
/ Grid-tied solar #1,000
Exactly. The batteries are not designed for everyday discharge/charge cycle. But as emergency supply they are OK. Generator is cheaper but it is noisy and requires fuel. So depending on circumstances the battery might be even cheaper to operate.
2015 Freightliner M2 106 Crew Cab Dump Truck (A61573)
2015 Freightliner...
Grain Auger (A64119)
2024 MAHINDRA ROXOR OFF ROAD UTV (A64280)
2024 MAHINDRA...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2012 Ram 1500 Crew Cab Pickup Truck (A61573)
2012 Ram 1500 Crew...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
