Loader Gresae fitting for loader lever b2320
   / Gresae fitting for loader lever b2320 #11
I will give the penetrating oil a try.
Thanks!
So are you just going to spray oil where the lever bolts to the control valve>? I would like to do the same to my B2320.
I sprayed around the entire area with Tri-flow. Has Teflon that seems to stick where u want it. Mechanism feels a wee bit better.
When the rain stops I will continue the 230' of French drain and moving the 23 tons of 2B.
I will let you know if it made an improvement.
Rob
The Tri-flow did the trick. The valve functions and releases as well as it did when it was new.
Wish I had tried that a while ago.
Thanks,
Rob
Toro TRX-20 Walk Behind Trencher (A57453)
Toro TRX-20 Walk...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57453)
New/Unused 20ft...
Peterbilt 377 Semi-Truck (A56438)
Peterbilt 377...
2025 GIYI GY-P45 Hydraulic Breaker Skid Steer Attachment (A56860)
2025 GIYI GY-P45...
Metal Sasquatch (A57454)
Metal Sasquatch...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
