GREASING DECK BEARINGS
/ GREASING DECK BEARINGS #1
lstumper067
North Mississippi / Nash Ridge
Kubota BX2230/Ramrod mini skid loader/Carlton stump cutter
I have heard that some bearings can be over greased. /forums/images/graemlins/confused.gif(sealed bearings) Does anyone know how many shots of grease should be applied to the deck bearings. The manual on my BX2230 shows the grease points but does not indicate how much grease. Can these bearings be over greased?
BX2230 with 60" MMM
stumper /forums/images/graemlins/smirk.gif
/ GREASING DECK BEARINGS #2
I had the same questions as you. Below is the response that I received from Kubota.
</font><font color="blue" class="small">( Thank you for contacting Kubota. I suggest that you grease them after each ten hours of actual use. Apply grease until you see excess grease slightly weeping from the spindle shaft seals. This should ensure a long and reliable life for our mower. )</font>
Thanks, JWE, just the info I was looking for.....question..what about that middle bearing, the fitting is on the side of the mounting so does that grease have to travel thru a tube or someting to get to the bearing? And can you see the grease coming out of that bearing??
Thanks much,
Stumper
/ GREASING DECK BEARINGS #4
I DON'T BELEIVE those are sealed bearings. usually if they have grease fittings they are not sealed. just grease them till some strts to seep out, and u should be good to go.
/ GREASING DECK BEARINGS #5
yeah, jetman is right, If it's got a fitting, grease it like hell, you can't go wrong. coonbone /forums/images/graemlins/wink.gif
/ GREASING DECK BEARINGS #6
I have not noticed grease weeping from the spindles. I have a pneumatic grease gun and I give each spindle 4 shots.
John
/ GREASING DECK BEARINGS #7
</font><font color="blue" class="small">( I have heard that some bearings can be over greased. /forums/images/graemlins/confused.gif(sealed bearings) Does anyone know how many shots of grease should be applied to the deck bearings. The manual on my BX2230 shows the grease points but does not indicate how much grease. Can these bearings be over greased?
No , you cannot overgrease a bearing. You can however pump more thru the bearings than need be. This will in turn leave a mess somewhere in your yard or driveway.
/ GREASING DECK BEARINGS #8
I could pump grease till the cows come home and not see any come out. Where does it go?... In those cups on the bottom of the deck. Pump it till your happy /forums/images/graemlins/blush.gif, then give it one more shot for luck! /forums/images/graemlins/wink.gif
/ GREASING DECK BEARINGS #9
I started a post on this topic about two years ago. My 60" MMM on my B7500 will NEVER weeps grease. When I first got it, I tried to grease and the pumps on the gun were so hard, I thought I would blow a seal or a hose. I now grease it first time of the season, and mid season, depending on use, or more if needed. I only give it a few pumps each zerk. I did grease it this year, first time, and gave each only 5-6 pumps. No weeping appeared, but after I mowed, the covers had a band of spent grease all over them from the spindle throwing it. Look back at the old threads.
/ GREASING DECK BEARINGS #10
I've heard that it is very bad to get that stuff on the belts. I would have thought it would just wear off with no problems. Does anyone know about that?
/ GREASING DECK BEARINGS #11
grease never wears off of the belts, it just glazes them so they slip. Once you get grease on a belt, it is best to toss the belt and install another. Small amounts might not cause much of a problem, but if it is a big glob, then it is "burnt toast".
/ GREASING DECK BEARINGS #12
junkman tells it straight, grease or oil will just glasze, then even if it appears to be working right there will still be some slippage.
/ GREASING DECK BEARINGS #13
Wash the grease off the belt using diesel fuel or kerosene. Let the belt dry before using it.
/ GREASING DECK BEARINGS #14
FYI, I just finished replacing the upper spindle bearings on my 60" mid deck (RCK60-27B) because they were getting very noisey. After taking them apart I found that they were not getting grease, therefore running dry. oops!! Obviously when doing my regular scheduled maintenance, I was not pumping ENOUGH grease into them. /forums/images/graemlins/frown.gif The grease that I had been pumping into the spindles tended to settle down on and around the lower bearing, leaving the upper bearings without grease.
So my advice (assuming your upper and lower grease seals are in good shape) is to pump grease in until you feel some resistance on the grease gun handle. Also, each spindle looks to hold about a FULL CUP of grease which amazed me. Good Luck /forums/images/graemlins/cool.gif
21ft. T/A Homemade Parade Float Trailer (A66736)
21ft. T/A Homemade...
2014 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A65056)
2014 CATERPILLAR...
Unused 2022 HLA 60in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
2025 Wolverine ADB-13-1218R Hydraulic Auger Set Attachment (A66734)
2025 Wolverine...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
2005 JOHN DEERE 310G BACKHOE (A65053)
2005 JOHN DEERE...
