grease zerk problems
/ grease zerk problems #1
Lebneh
North East
John Deere 3720
So, a grease zerk on my loader broke off. I eventually got the broken piece out but not before I damaged the threads. I bought a replacement zerk and took it to Ace Hardware to find the proper size tap. The guy there recommended 1/4 -28 but did not have any. He said it might need to be tapered thread.
I was looking around on the internet and foudn this... Amazon.com: Irwin Tools 2623- 3 Piece High Carbon Steel - Tap 1/4" - 28 NF: Home Improvement
Do you guys think this will do the job? All suggestions are appreciated and a link to the item to buy would be a real big help.
Machine info:
John Deere 3720 with the 300CX Loader
Frontier AY11E - 72 In. 4-In-1 Bucket (the zerk is on the bucket)
/ grease zerk problems #2
1/4" - 28 is the size. I think I got mine at NAPA...
DJ, thanks for the feed back, makes me feel a little better about it.
/ grease zerk problems #4
1/4-28 and 1/8 NPT at the 2 most common i think. unless it is metric
/ grease zerk problems #5
It is probably 1/4-28, however I think grease zerts use a tapered thread (NPT), whereas a NF tap is not tapered. You will need to remove the pin to dress up the threads.
/ grease zerk problems #6
Not sure what your loader is but there is a strong possibility there were no threads to mess up. Many companies use drive type zerks. All they need is a plain drilled hole, no threading (cost) or damaged threads (more cost). The zerk looks like a barb fitting for plastic pipe but on a much smaller scale. Check your hole diameter to make sure you have enough material to tap and fit a replacement or you will need to go oversize.
/ grease zerk problems #8
I think I read the taper is 3/4" per foot. NAPA had at the time, a tap for grease zerks. Reasonable, so I bought two. Depending on how deep you boogered the threads, it may be tough to clean them all up with the pin still in there.
/ grease zerk problems #9
i use the same tools that poorplowboy linked to.. got mine at tractor supply.. they work fine.
remember.. if the hole is slightly od.. hit the open face with a hammer to shrink the hole...
I looked up the part number on JD's parts page. Here is the mystery part.
Looks like it's confirmed 1/4-28. I already bought a tool similar to the one suggested by PoorPlowboy (thanks for the link!).
The question is should I use that tool to fix the threads or just sink in "self-forming threads" zerk into the hole and hope for the best.
Thanks for all the input guys.. All suggestions are welcome and appreciated!
John Deere Grease Fitting - JD7844
/ grease zerk problems #11
you have the tool with the chase.. use it....
So I ended up testing on some scrap and it seems like either the grease zerk tool or the 1/4-28 taper tap that I bought would work.
I ended up just using the zerk tool on the broken zerk. Seems to be all set now.
John Deere Telescopic Lift Arms (A65640)
John Deere...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
Land Hero Mini Skid Loader (A66408)
Land Hero Mini...
NEW Wolverine PD-12-08D Skid Steer Post Pounder (A62679)
NEW Wolverine...
2021 CATERPILLAR 299D3 XE SKID STEER (A65053)
2021 CATERPILLAR...
17601CFL (A59228)
17601CFL (A59228)
