grease zerk problems
/ grease zerk problems #1
Lebneh
North East
John Deere 3720
So, a grease zerk on my loader broke off. I eventually got the broken piece out but not before I damaged the threads. I bought a replacement zerk and took it to Ace Hardware to find the proper size tap. The guy there recommended 1/4 -28 but did not have any. He said it might need to be tapered thread.
I was looking around on the internet and foudn this... Amazon.com: Irwin Tools 2623- 3 Piece High Carbon Steel - Tap 1/4" - 28 NF: Home Improvement
Do you guys think this will do the job? All suggestions are appreciated and a link to the item to buy would be a real big help.
Machine info:
John Deere 3720 with the 300CX Loader
Frontier AY11E - 72 In. 4-In-1 Bucket (the zerk is on the bucket)
/ grease zerk problems #2
1/4" - 28 is the size. I think I got mine at NAPA...
DJ, thanks for the feed back, makes me feel a little better about it.
/ grease zerk problems #4
1/4-28 and 1/8 NPT at the 2 most common i think. unless it is metric
/ grease zerk problems #5
It is probably 1/4-28, however I think grease zerts use a tapered thread (NPT), whereas a NF tap is not tapered. You will need to remove the pin to dress up the threads.
/ grease zerk problems #6
Not sure what your loader is but there is a strong possibility there were no threads to mess up. Many companies use drive type zerks. All they need is a plain drilled hole, no threading (cost) or damaged threads (more cost). The zerk looks like a barb fitting for plastic pipe but on a much smaller scale. Check your hole diameter to make sure you have enough material to tap and fit a replacement or you will need to go oversize.
/ grease zerk problems #8
I think I read the taper is 3/4" per foot. NAPA had at the time, a tap for grease zerks. Reasonable, so I bought two. Depending on how deep you boogered the threads, it may be tough to clean them all up with the pin still in there.
/ grease zerk problems #9
i use the same tools that poorplowboy linked to.. got mine at tractor supply.. they work fine.
remember.. if the hole is slightly od.. hit the open face with a hammer to shrink the hole...
I looked up the part number on JD's parts page. Here is the mystery part.
Looks like it's confirmed 1/4-28. I already bought a tool similar to the one suggested by PoorPlowboy (thanks for the link!).
The question is should I use that tool to fix the threads or just sink in "self-forming threads" zerk into the hole and hope for the best.
Thanks for all the input guys.. All suggestions are welcome and appreciated!
John Deere Grease Fitting - JD7844
/ grease zerk problems #11
you have the tool with the chase.. use it....
So I ended up testing on some scrap and it seems like either the grease zerk tool or the 1/4-28 taper tap that I bought would work.
I ended up just using the zerk tool on the broken zerk. Seems to be all set now.
Wolverine Quick Attach Brush Mower (A66408)
Wolverine Quick...
2017 Hyundai Santa Fe AWD SUV (A64557)
2017 Hyundai Santa...
1991 BMY 6x6 Wrecker (M936A2) (A62613)
1991 BMY 6x6...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
2004 John Deere 8320 (A63688)
2004 John Deere...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
