Grease - is there no better way? Can we talk about this?
   / Grease - is there no better way? Can we talk about this? #21
We bought a cordless ryobi grease gun, it leaked so bad I went back to a manual one with a lock & lube. I use synthetic grease on the Bransons.
I also keep a roll of paper towels near the grease guns.
   / Grease - is there no better way? Can we talk about this? #22
One of the things I hate most about working with equipment is grease. I recently decided I was going to make it easier by getting a battery powered grease gun. Then I opted to put a lube lock fitting nozzle thingy to try to reduce the mess.
It helps but the grease and mess still gets everywhere.
All over my hands. Ruined countless numbers of rags. All over the tractor in places I'd rather not have it. All over the grease gun and even some of my other tools.
Is there a better way? Are there any products I should look into?
Is there no newfangled alternate to grease that isn't quite so messy?
Clothe
Grease makes the already unpleasant task of maintaining equipment even less pleasant.
Clothe your grease gun in an old cotton sock. Change as needed.
   / Grease - is there no better way? Can we talk about this? #23
When young, my dad insisted I grease his equipment until 100% clean grease came out. We went through a WHOLE LOT of grease!
I have greased my equipment as you do for many years.
What a lot of people don't realize is that too much grease in a ball bearing makes it run quite a bit hotter untill the excess grease is pushed out of the bearing. Whether that's bad for the bearing I don't know. What I do know is that pushing the seal off by over greasing is bad for the bearing.
   / Grease - is there no better way? Can we talk about this? #24
I've had guys on my crew grease tractors to the point I couldn't hardly walk by the tractor without ruining clothing. The grease that oozes out of pins and bores does no good; Usually I pump one shot per fitting and occasionally wipe up the mess with a gasoline soaked paper towel.
   / Grease - is there no better way? Can we talk about this? #25
I wear a pair of cheep leather gloves. I wipe off the grease fittings with them and what ever else needs wiping. Once they get too dirty I rub a healthy dose of hand cleaner into them and throw the gloves into the wash with my work clothes. I let them air dry and reuse them till they are worn out.
This keeps my hands and clothes relatively clean enough so that they not usually an issue to operate equipment.
The grease gun nozzle usually gets wiped off on the grass or tire or what ever else is handy. If it's really bad then a wipe with a paper cloth is usually sufficient to clean it up. Once in a long while the whole grease gun will get a bath in my varsol tank or more often lately just a good spray down with brake clean.
I'm of the opinion that a lot of people think that if a little grease is good then a lot is better. My mower deck bearings only get 2-3 shots. Any more and you run the risk of pushing the seals out. Any needle bearings don't need more than the same. Bushings I like to see the grease come out somewhere but I'm probably over greasing them. U-joints get grease till it comes out all 4 of the needle bearings. That way you know that all 4 got grease.
I don't grease the telescoping part of u-joints at all. [[[Spraying WD40 is good enough for me.]]] I hate it when the telescoping part gets so full of grease and dirt that it's a struggle to get it to move. Yes it wears out faster the way I'm doing it but it won't wear out in my lifetime. I'm good with that. I lube my pto connections the same way for the same reasons.
If you ever pressure wash your equipment make sure you grease it and use it a bit after. It pushes the water out of all the bearing surfaces. Your ball bearings will thank you by lasting longer.
Best Iv found. Slick. Sticks. Does not evaporate.
Amazon.com
   / Grease - is there no better way? Can we talk about this? #26
I keep a roll of paper towels next to the 5 gal. bucket that the grease guns are put into.
I also store my grease guns in a 5 gal. bucket and am surprised at how much oil leaks out of the grease and collects at the bottom of the bucket.
I did some research and discovered that grease guns should be stored horizontally and not vertically. In horizontal storage, less oil will separate from the grease and the oil that does separate tends to stay in the grease tube.
I plan to now store my guns on a large cookie sheet.
   / Grease - is there no better way? Can we talk about this? #27
I agree that greasing eqiptment is a major PIA. I have a Milwaukee battery powered gun that is just about impossible to purge air from. I also have used the grease fitting lock device with mixed results. I use cream colored synthetic grease that makes me think everything is cleaner even though it isn't
   / Grease - is there no better way? Can we talk about this? #28
Years ago I was doing some tractor work for a local nursey.
I was supposed to go and rototill a field for planting.
I hitched up and went to get the grease gun to lube everything before starting. Just like I would do on the home farm.
When I couldn't find the GG I went and asked the owner.
He said, "I don't like to grease equipment. It makes a mess."
"OK"
I went to work.
After an hour one of the U-joints broke. The needle bearings were just rusty dust.
It was all my fault for abusing the equipment.:mad:
Next day he had a GG.
I was just there to get my 1 days pay and I was out of there.
Your equipment will stay nice and clean if you don't grease it.
It will be broken with no chance of getting dirty.:ROFLMAO:
All too true. I once worked on a farm whose owner didn't like to take time for routine maintenance. One busy summer day the guy in charge of our day's work handed me a grease gun and told me to get all the silage wagons and the silage blower greased while he did the chopper. The owner chewed us out for "wasting" half the morning...but that summer we had no failed bearings or other breakdowns due to lack of lubrication.
My solution to the messy hands is buy gloves. Harbor Freight sells boxes of nitrile gloves that last at least long enough to do one full lube cycle on all my equipment. I also keep lots of shop towels around.
   / Grease - is there no better way? Can we talk about this? #29
grease or new parts $$$. I will take grease anytime no matter how messy. besides it shows anyone that sees it that I care about my equipment.
   / Grease - is there no better way? Can we talk about this? #30
I like my electric grease gun so much, I bought another one. I keep Molly in one and Red & Tacky in the other. I use a manual one I converted to use way oil for my Mill. The Mill has grease fittings but they are for oil.
Side Note: If your Lock & Lube tip is leaking, replace the rubber seal with one of the extras they give you. If it's still leaking, your grease fittings are probably clogged--Replace them. If it's still leaking, clean the grease paths.
What kind of oil do you use in your grease gun for your mill?
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
New/Unused Mini Skid Steer Grapple (A57454)
New/Unused Mini...
2023 CAN-AM HD7 RTV (A59823)
2023 CAN-AM HD7...
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A57453)
2007 Hino 268...
20ft Shipping Container (A57453)
20ft Shipping...
CAT 336E (A58214)
CAT 336E (A58214)
