diesel_nut
Greasing steering box on 2500 Series, Pics
OK. I did the "dirty deed". Not all that bad and you don't really have to remove the steering box cover, but I did anyway to show what happens when you do it the way Cub spells out.
Remove wing nut (red arrow). Then pull bolt out. This is located on left frame rail just in front of the left floorboard:
Pull top of cover out and then slide cover down(they say to remove it, I think, but no need to do that. Disregard arrows for now. Next two pictures:
From here it's easier to put grease gun on zerk fitting from under the tractor(just above front of deck) Grease fitting is at end of arrow:
Now, to see if you got enough grease in, see 3rd picture and see red arrow pointing at grease(red) coming out of steering shaft.
Now, raise cover back in place. See 2nd picture and make sure the tabs are in place correctly. Green arrow shows this tab goes over the other cover and the red arrow shows this tab goes under other half of cover(blatantly obvious when you do it).
Replace bolt and wing nut. You are done.
Very easy.
Very easy.
