grease gun accident
   / grease gun accident #1
Redneck_Randy
Platinum Member
Oklahoma
2005 New Holland TC35A
be careful removing your grease gun tip from a zert. mine got stuck and when it came off my hand went flying back and hit the FEL brace. picture tells it all.
Randy
Randy
   / grease gun accident #3
Yikes, major bummer!!! I can relate as I serviced my backhoe and loader just yesterday. Why isn't there a grease tip with a slide collar that releases easily when pulled back?
Broken? How bad? You can print off all the TBN signatures and stick them on /forums/images/graemlins/smile.gif
   / grease gun accident #4
   / grease gun accident #5
OOF /forums/images/graemlins/crazy.gif Am sure that hurt!!!
Hope all recovery goes well..... and that you are soon back in the seat again!
   / grease gun accident #6
   / grease gun accident #7
Removing a grease gun tip from a zerk is a different technique than attaching to the fitting. When attaching, one pushes the tip dead-on in order to make the seal. After applying the grease though, you should grasp the tip and pry it off with your hand if you are using a flex hose. If using a fixed fitting, then you can just pry the fitting off by moving the gun at an angle. I have the Lincoln pneumatic gun, and this works well for me. I believe most tips have a strong spring of some type that needs to grasp the zerk in order to seal tightly. A buildup of old grease will cause the tip to get stuck, as will a piece of fine grit.
May God speed your healing,
AB
   / grease gun accident #8
AB
   / grease gun accident #9
<font color="blue"> A buildup of old grease will cause the tip to get stuck, as will a piece of fine grit.
</font>
I've also found that pressure from the grease will make it more difficult to remove the grease gun. When I've had a stuck fitting, I found that waiting a bit to allow the pressure to relax allows for easier disconnect.
Jeff
   / grease gun accident #10
</font>
Jeff
2018 Nissan Murano SUV (A50324)
2018 Nissan Murano...
Pro Tech 16' Snowbox (A50774)
Pro Tech 16'...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2024 John Deere 6110M (A50120)
2024 John Deere...
1982 S&S FLATBED (A52472)
1982 S&S FLATBED...
