grease gun accident
   / grease gun accident #1
Redneck_Randy
Platinum Member
Oklahoma
2005 New Holland TC35A
be careful removing your grease gun tip from a zert. mine got stuck and when it came off my hand went flying back and hit the FEL brace. picture tells it all.
Randy
Randy
   / grease gun accident #3
Yikes, major bummer!!! I can relate as I serviced my backhoe and loader just yesterday. Why isn't there a grease tip with a slide collar that releases easily when pulled back?
Broken? How bad? You can print off all the TBN signatures and stick them on /forums/images/graemlins/smile.gif
   / grease gun accident #4
   / grease gun accident #5
OOF /forums/images/graemlins/crazy.gif Am sure that hurt!!!
Hope all recovery goes well..... and that you are soon back in the seat again!
   / grease gun accident #6
   / grease gun accident #7
Removing a grease gun tip from a zerk is a different technique than attaching to the fitting. When attaching, one pushes the tip dead-on in order to make the seal. After applying the grease though, you should grasp the tip and pry it off with your hand if you are using a flex hose. If using a fixed fitting, then you can just pry the fitting off by moving the gun at an angle. I have the Lincoln pneumatic gun, and this works well for me. I believe most tips have a strong spring of some type that needs to grasp the zerk in order to seal tightly. A buildup of old grease will cause the tip to get stuck, as will a piece of fine grit.
May God speed your healing,
AB
   / grease gun accident #8
AB
   / grease gun accident #9
<font color="blue"> A buildup of old grease will cause the tip to get stuck, as will a piece of fine grit.
</font>
I've also found that pressure from the grease will make it more difficult to remove the grease gun. When I've had a stuck fitting, I found that waiting a bit to allow the pressure to relax allows for easier disconnect.
Jeff
   / grease gun accident #10
</font>
Jeff
FORREST RIVER CHEROKEE CAMPER (A50854)
FORREST RIVER...
2018 East Texas Utility Trailer (A49461)
2018 East Texas...
Ford 4x4 Pickup Truck Bed (A49461)
Ford 4x4 Pickup...
1274 (A50490)
1274 (A50490)
2006 KOMATSU D41P-6 CRAWLER DOZER (A51222)
2006 KOMATSU...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
