greasable pin?
/ greasable pin? #1
mopardude318
Platinum Member
Hollister Ca
Kubota M7060 HD12 Oliver 550
Is there a source for a greasable CAT 2 3PH pin?
Having hydraulic top n tilt, and a heavy box blade on 100% of the time, I constantly use and adjust the top link. would it make sense to have those lower pins greasable, or forget about it?
/ greasable pin? #2
My loader pins have a zerk in the center so likely they are available. Are you refering to the pins that attach to the lower link swival eyes?
I have hydraulic top link and Pat's quick attach on lower links. Never thought about the need for lubrication at those points, Are you noticing excessive wear?
/ greasable pin? #3
that grease is going to attract dirt and grit in such a dusty location which will cause faster wear, leave it dry
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
(2) Firestone 18.4-16.1 Tires w/Rims (A64127)
(2) Firestone...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
Landhonor Quick Attach Tree Puller (A66285)
Landhonor Quick...
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
Titan 20.5-25 Tires (A65640)
Titan 20.5-25...
