greasable pin?
/ greasable pin? #1
mopardude318
Platinum Member
Hollister Ca
Kubota M7060 HD12 Oliver 550
Is there a source for a greasable CAT 2 3PH pin?
Having hydraulic top n tilt, and a heavy box blade on 100% of the time, I constantly use and adjust the top link. would it make sense to have those lower pins greasable, or forget about it?
/ greasable pin? #2
My loader pins have a zerk in the center so likely they are available. Are you refering to the pins that attach to the lower link swival eyes?
I have hydraulic top link and Pat's quick attach on lower links. Never thought about the need for lubrication at those points, Are you noticing excessive wear?
/ greasable pin? #3
that grease is going to attract dirt and grit in such a dusty location which will cause faster wear, leave it dry
Paladin 12in Bucket w/ Teeth Excavator Attachment (A64194)
Paladin 12in...
208735 (A60430)
208735 (A60430)
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
