Gravely tractors
/ Gravely tractors #1
royl
Blairsville, GA
Gravely commercial 10A
I'm a new member always looking for interesting topics relative to using my Gravely walk behind tractor and implements; also other tractor topics as well. Presently would like to hear of comparisons between the bush hog and sickle attachments from owners who have both. Specifically, I have a 1+ acre investment lot that is overgrown with tall grasses and some 1" or less saplings. My 40" finish mower on my Gravely Com. 10A doesn't do well at all with cleaning this up. Which would be better to cut this and maintain it, the sickle bar or the 30" bush hog on my Gravely? What length sickle bar would be best? (I have some ups and downs on this property by nothing severe). Thanks!
/ Gravely tractors #2
you might consider to also put your thread on the general lawn/garden forum, bet there are some experienced gravely walk behind members there. is this the older (long discontinued) hd model? good luck
/ Gravely tractors #3
I have both mower attachments, the 30" rotary mower and a 60" sickle bar. I also have 1-2 acres that I typically mow maybe twice a year here in Pa. The sickle bar is my preferred implement. Having said that, you need to know which L Gravely you have. I think, if I remember correctly, the Li is a low range differential gear and it runs exceptionally slow over the ground. The standard L runs faster. I point this out because I usually run pretty slow (slow walk) to cut grasses/weeds/light trees that are chest high or higher. The Li is really perfect for the job. The L will do it, I just need to slip the clutch frequently.
The L is a great machine. Like the energizer bunny, it just runs and runs and runs.
/ Gravely tractors #4
Actually, there is a Gravely-specific sub-forum where the vintage Gravely folks hang out....
With my C10, I wouldn't use the sickle on 1" saplings as it will need to "saw" through them. Sickle would be best for grass and/or very light growth (IMHO).
Chris42, do you have some sort of skids on each end of your sickle? If so, might you share a photo?
- Jay
/ Gravely tractors #5
Hello Jay,
(sorry for the side track royl) I do have skids on the sickle bar, and I agree, they (sickle bars) do have to kind of chew through small trees. My skids are standard Gravely hardware. While I don't have pix, I'll describe them and figure you can do some visualization -
Made from steel, half round and turned up at both ends, much like a skate board.This allows movement forward and back without catching cut grass. In the middle there is a threaded stud sticking straight up, maybe 3" long. This replaces a bolt on the sickle bar.
rough design pic: \___ I ___/ The "I" is obviously longer and threaded it's entire length. A nut above and below the bar adjusts the height. They reach in front of the teeth and well behind the bar. The stud is centered, so there is no right end for the front/back.
The manual has the skids mounted out close to the ends. I mount mine much closer to the middle, pretty much dividing the bar into thirds. Mounted further out tends to bow the bar in my experience.
Sometimes while mowing the sickle bar will clog. I find that at the right ground speed it will frequently self clear. Being sharp certainly helps.
Royl - yes the sickle does need to move very, very slowly through small saplings. On the other hand the brush hog will keep moving and beat them into submission. Note too that you can mount TWO blade to the brush hog, one above the other. At some point they made blades to intentionally pair them this way (different bend offsets) and they cut in the same plane. For rough work this doesn't really matter - it's two extra edges cutting what you want cut. It's pretty unlikely that you will stall the machine with this set up (it is pretty unlikely that you will EVER stall the machine).
/ Gravely tractors #6
Excellent, thanks, Chris! My sickle had some rusted and mangled remnants of something like those skids when I got it, but they seemed to be a home made item rather than the usually STOUT Gravely design. Is there anything other than tightness of the skid nut to keep them from turning around?
-Jay
/ Gravely tractors #7
I had an older pull start L (8 hp Kohler?) and thought the 30" rotary was the implement best matched to the machine. Would cut anything and balanced real well.
Also had a 36"(?) sickle and it clogged a lot in the fine grasses (June grass, called here) we have. And shook the machine more than the rotary. My rotary had a 30 lb weight welded on the front top, maybe helped with the balance.
Sickle had skids but open on the rear so snaggy when reversing, prob not oem.
Kind of wish I'd kept it, but took up lots of space and was too long to blow snow or rotary plow. .
Jim
2018 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A67737)
2018 FREIGHTLINER...
2006 Ford F-750 Terex Commander C4047 Digger Derrick Truck (A68183)
2006 Ford F-750...
2019 Toyota Camry Hybrid Sedan (A66738)
2019 Toyota Camry...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
2013 WACKER NEUSON LTN8 LIGHT PLANT (A68842)
2013 WACKER NEUSON...
ACETYLENE AND OXYGEN BOTTLE (A68842)
ACETYLENE AND...
