Grasshopper mowers
/ Grasshopper mowers
I've got an older 928d that I found on C.L. I payed $5,000.00 for it.It's the best mower I've ever owned.It's a front mount 60" deck.I'm going to change the truff tires over to the rib style to give me better traction as I mow a couple acres of my property with it.There are plenty of vendors around here that sell them as well as parts as they are made here in Ks.If you need help you can call GH and they give good feedback on problems you are having...russ
Thanks for the input!
930 is a bigger heavier mower than my 725, I hear they have really good power output... I just didn't feel I needed that extra power of the 930 when I bought my 725.
SR
That was my dilemma as well... If the added weight justified the 20% power increase.
The deal decided for me, as I found a 930D with a cab, snow blower, and 72" deck side discharge deck for $7,000.
I wish it was a rear discharge, but the deal is hard to pass up. The RD decks are hard to find... but the flail mower I plan on attaching is capable of both rough and finish mowing. The flail also has a full-length roller and stripes like you wouldn't believe.
I use the 725d for mowing, leaf collection and snow blowing. The winter enclosure stays on year round. I mounted a small RV fan inside and had an upholstery shop convert the vinyl side window doors to nylon screen and zippers on the vinyl so ventilation is adequate. They are tough, working, beastly unstoppable machines. They complement a tractor for other tasks.
Get the Kendra turf tires and the tandem rear dual tail wheel option and the extra flotation will leave no tracks even when wet. If time is an issue get a grasshopper. Just put in the ear plugs and the ear muffs. Very loud.
Thanks for the tips!
I haven't used one with a diesel engine, but I love my 729BT 61" deck with the Vanguard 29hp Big Block in it. Mine has the PowerFold deck, and it will really spoil you when it comes to blade changes and deck cleaning.
Grasshopper mowers are built like tanks.
We have 725 K (gas) 27 HP Kohler over 1200 hours. It needed a new generator (corrosion), two electric clutches (worn out), several tires, new spindle bearings and few other small things. It cuts about 8 acres full of obstacles (about 2000 trees) and quite hilly once a week. They are very easy to rebuilt I suppose. My estimate for all new bearings, engine, hydraulic pumps/motors, pulleys, linkages etc about 7500 to rebuild to like new condition. I would buy used and fix it as needed.
That's my intention.
I found a 930D with 2,000hrs for $7,000... that's including the snow blower, cab, and 72" side discharge deck.
/ Grasshopper mowers #26
A rear discharge deck on a front deck mower just blows a lot of junk on you and in the intake of the motor...
I don't think you would like that combo, UNLESS you are in green grass "all the time", and mowing nothing that is dry at all...
SR
SR
You'd be surprised.
I've always preferred rear discharge, except in the case of lush and wet finish mowing, as they tend to clump.
In my experience, side discharge has been worse than rear or mulching in the dry... as the cast has far less deflection to be thrown in the air.
/ Grasshopper mowers #28
If anyone is considering a front mount mower, check out Walker before buying if possible. If you haven't seen one in action you don't know what you're missing.
Kevin
Kevin
Walker makes great finish mowers... but they're not very versatile.
They also lack a diesel unit over 24hp.
For commercial finish mowing on level ground, they're hard to beat... which is their market focus, and why they're still around.
They're one-handed center control levers and static speed control are nice. In my opinion... For one-handed control, Country Clipper has them all beat with their joystick control. A 930D Grasshopper with the same setup would be killer. ****, I'd love to have a Joystick control on my Toro.
/ Grasshopper mowers #30
Not me, on side hills I hang onto the steering column with one hand and steer with the other hand. :thumbsup:
/ Grasshopper mowers #31
You'd be surprised.
I do like rear discharge decks, just NOT on a front mount machine, like my GH... Ever try one on a GH? They are fine in town, but not so much out here in the country with all kinds of different terrain making dry grass and dust fly...
SR
/ Grasshopper mowers #32
I have lots of friends with Grasshoppers and none of them would switch. There area also a lot of the old Grasshopper built Woods mowers around here as well - very well liked. Of course we have a great dealer locally and a few others around.
The only reason I do not have one is that in '97 when I bought my mower - Deines was the only one with a flip up deck and I wanted it. The cost factor didn't hurt any on the Deines either as Grasshopper does love their product.
/ Grasshopper mowers #33
So glad I found this thread! I'm reviving it just because! There is is barely any info out there on these tractors (if you can call it that) in forums! Prob because it's mostly used commercially. I'm about to buy a grasshopper, comparing a new unit to used ones myself. Currently leaning toward new, but still hoping a clean used one falls into my lap, because that price tag is crazy! Does anyone have any thoughts on the G2 vs T6 trans? I haven't found anything bad about the T6, but the G2 is still offered on the 900 series so that says something to me. Also I'm eyeing up a rear discharge deck, but there is even less info out there on that thing! It has an additional blade to eliminate windrowing, but idk. It cost more too, so another reason to really be sure it's what I want.
/ Grasshopper mowers #34
Grasshopper has some good listings as do several other upper priced units. I shopped them with Bad Boy and numerous others. I had 2 complaints with my mowers: Scotts 42 HST, JD L110 42 HST, Hustler Fastrak 44 ZT, Husq, 46 HST, DR Pro Z 52 HST and that was clippings out the shoot blowing back in my face when mowing and rough ride on my rough turf. I bought the Ferris 61" with the BS Vanguard 26 because of the suspension and the way the deck is setup it develops a real whirlwind which blasts the clippings out the chute far enough away to keep them out of my eyes. I had thought for a long time I too wanted a rear discharge but after reading around and thinking about it I decided that was not the best option for tall grass which I usually mow....for the "recommended" clipping of 1" per pass then rear should do fine.
If suspension is not an issue with you, no reason not to go Grasshopper as I see it. Not that there is anything wrong with theirs, I watched a commercial guy cut the hospital's parking lot one day and that convinced me the Ferris would be my choice....even at that and it being a new machine, I added springs to the seat and bought golf cart balloon 22x11-10 traction tires running them at 10 psig, and put a canopy on it. Now I'm happy. Wink!
/ Grasshopper mowers #35
Around here I think the Grasshopper is the most popular mower commercially or homeowner. They are great mowers - I think the best - especially the front deck models which flip up for easy blade access and you can get under bushes and low hanging branches much easier. They have such a low center of gravity and wide stance that you cannot tip them - they slide first - even with the chevron tires. their low Cg also makes them great hill handlers, either up and down or sideways. The decks handle a large amount of material very well.
The only negative I know about them is that parts for units over 20 years old may not be available as they do have special parts and are not made just out of other manufacturers components. And of course the price but I would not shy away from one with 2000 hours on it if it looks like it has been cared for.
/ Grasshopper mowers #36
Well I'm undecided on everything, but I'm getting one next week come **** or high water. My dealer quoted me 14,900 for a 2017 725dt with grammer susp seat, folding rops, 61" rear discharge, free break in service, an extra set of blades and 0% for 48. The rear discharge is a 500 option, but I'm pretty sure I want it. I'm gonna call about a clean 2005 722d susp seat and 61" side discharge tomorrow with 800 hours for 6900. Not sure which way I'll go, but After mowing today, I'm getting a grasshopper this week.
/ Grasshopper mowers #37
Well I'm undecided on everything, but I'm getting one next week **** or high water. My dealer quoted me 14,900 for a 2017 725dt with grammer susp seat, folding rops, 61" rear discharge, free break in service, an extra set of blades and 0% for 48. The rear discharge is a 500 option, but I'm pretty sure I want it. I'm gonna call about a clean 2005 722d susp seat and 61" side discharge tomorrow with 800 hours for 6900. Not sure which way I'll go, but After mowing today, I'm getting a grasshopper this week.
We have 725K that is about 20 years old with 1200 hours. It has second engine. First engine was wrecked by our own fault due to low engine oil while mowing very steep slope. It has second electric PTO clutch and few new bearings in spindles (due to neglected lube). Other parts such as new blades, V belts and etc are consumables that I changed at about 1000 hours. The design is simple enough so they are easy to repair and/or overhaul by DIY. No special tools required. If you are handy I wouldn't be afraid to buy the used.
/ Grasshopper mowers #38
Agree on the chevron slippage. I mowed pool (pond) banks with my DR which at 900# was a pretty good weight to move up, down, and sideways of the banks. Obviously the OEM turfs came off and I put chevrons on thinking they would do the trick. They didn't. Went to ATV studded snow tires with the individual posts and that did the trick. However, you had to be real soft with the controls in making Z turns to keep from digging up turf but you can do it, just be easy. The golf cart traction tires I put on the Ferris are a good combination of stud and turf.
/ Grasshopper mowers #39
I really like the power fold deck on my GH, it sure makes blade sharpening MUCH easier...
SR
That was one serious thought I had when I looked at them. No doubt about the convenience of being to tilt that deck up. The other thing I noticed was the front of the deck is sloping with deflector shields inside. The Ferris is like that too and clippings over the front are about non existent as evidenced by that little pile on the right corner in your picture of both mowers. My experience with the vertical front mowers without the internal deflector shields is wads and wads of clippings up on top around your spindles and drive mechanisms.
/ Grasshopper mowers #40
You will love the Upgrade seat, the deck adjustment and most everything about the Diesel engine!! If it was all wheel drive I would have one today by far best bang for the buck.
Try height adjustment on a Kubota Front mount and you will be shaking your head lol
TARTER 180 CATTLE SWEEP (A64277)
TARTER 180 CATTLE...
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
(2) Assist Wheels (A64126)
(2) Assist Wheels...
76in. Skeleton Skid Steer Grapple (A65640)
76in. Skeleton...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
Stand-On Mower (A64553)
Stand-On Mower...
