Grapple Grappling for answers on Grapples
   / Grappling for answers on Grapples #11
Just my 2 cents worth here, but I have a little bit bigger tractor than most here at TBN and I use the Skid Steer loader Root Grapple Heavy Duty. Have had no problems with it. Very reasonably priced and will take a beating. In the 1st pic, I am sifting through the dirt with the front edge of the grapple about 6-8 inches in the ground, and as you can see, I also use it for moving bushes like a lot of others do also. Check them out before you buy. ;)
Good luck with what ever you get.
   / Grappling for answers on Grapples #12
Samandothers,
I appreciate your encouragement. The story about how I settled on the WR Long I did is short and simple: I worked with Ken Wilson of Wilson Equipment in Spartanburg setting up my tractor purchase...described to him what I wanted to be able to do...he showed me a couple of suggestions and I thought this one would reach into my overgrown treelines and take a big bite of junk. Since I'm situated on good 'ol North Carolina red clay, I didn't expect to be doing a whole lot of sifting so the closer spacing on the bottom of the grapple wasn't much of a concern. If I do get more soil in a load than I intended, I just drop the load a couple of times and go about my business.
Now, with a little more experience under my belt and the more time I spend on TBN, I realize half the fun of finding just the right attachment is the hunt! Kinda' feel like a kid in a candy store. Again, happy hunting.
   / Grappling for answers on Grapples #13
Samandothers,
I have had no issues with the strength of the top of the bucket. If you look at my link of where I added the grapple I reinforced the top of the bucket with 1/2" x 4" flat plate between the loader mounts. I then welded the grapple mount on top of that.
I added a tooth bar to the front of my bucket which makes it a lot easier to pick up poles etc.... I have had no issues with picking up brush. I just push the brush into a pile, pick up the bucket and roll it forward and the "clamshell" the pile. I can pick up a pile big enough I can't see to drive. I have also picked up logs big enough to make the tractor "tippy" even with a 55 gallon drum of concrete on the back and loaded tires.
Chris
   / Grappling for answers on Grapples #14
By the way I had not idea about cost of the item so I called a dealer listed on WR Longs site for a ball park intial price. It was about $700 for the hydraulics needed to prep the tractor and then for the 72" root rake with two top gapples was $2700 and the open bottom design in 72" was $2000. A bit more than I was wanting to spend even though it could be the wifes Christmas gift!:rolleyes:
That is why I pointed you to Markham. The other manufacturers of what are sometimes called "light duty" grapples like Long and Millonzi (RIP:() make (made) similar open bottom grapples in the 48 inch size that work very well with CUTs. The open bottom grapples are apparently much easier to manufacture so are always less money than the clam shell type (you are calling them root rakes but that term is used for both styles). The clamshells are also almost always heavier (not a good thing generally) for a given size.
One general bit of advice: be careful not to confuse grapples intended for commercial use on big skidsteers with what would work best on a CUT. Even your 42hp tractor with 852kg lift at mid bucket is light duty compared to what the skidsteer grapples are designed to handle. Again, my 41hp Kioti DK40se has over 2700lbs lift at PP and the Millonzi 48 inch "light duty" grapple has no complaints. I lift the rear of the tractor with ballast off the ground routinely trying to pry out stumps and the grapple shrugs it off.
   / Grappling for answers on Grapples #15
Great input thanks to all! Lots of different possibilities which is good! Now I need to read through these and visit some sites.
Pitt Md why did you select the open bottom design vs the root rake design?
With these other sites to visit
I chose the OBG design because I have large chunks of concret and big rocks to move as well as trees and brush. Clamshell designs rely on the clamping force to lift material as they can not get under an object. Part of why I chose that design was talking to Mr Long (Vance) from WR Long and telling him what I have to do. He advised the OBG type. Each design has it's pros and cons.
I would not recomend a 72" grapple for your tractor. Island tractor has pointed out the advantages of going smaller so I will not restate what he said.
One more thing...
if you intend to do any type of ag work i would recomend installing rear hydraulics. Very nice to have the ability to operate equipment on the back.
   / Grappling for answers on Grapples #16
One more thing...
I agree. I have used both rear hydraulics and a joystick mounted diverter. Both work well (I actually prefer the rear hydraulics by a hair so long as the control lever is easily reached by dropping your hand off the joystick). The rear hydraulic set up gives you the ability to easily add a hydraulic topping lift (great for box blading) and other hydraulically powered tools in the future. The diverter costs more and is a one trick pony.
   / Grappling for answers on Grapples #17
We use a Versatech root rake grapple on the front of our M4900. A bit bigger that yours in outer size. It works great for what we use it for, turning lage brush pile and large compost pile, carrying downed trees and such.
On thing though. Our hydraulics are a beast to hook up on our '05 M4900. Don't know if it is different on L's. With the QA up front, you'd expect things to be quick and easy. Not so with the Hydraulics.
Also, we got ours from Mcgrew Equipment in PA. Any experienced ebayer would know about the. We also got the Case 450 from them, which we have sold now.
Mtn. View Ranch the line to Unlimited Fabrication in Denton NC is appreciated. Good to have additional options.
I also visited Markham痴 site mentioned by Island Tractor and Happyman. Ironically they are also in Denton NC. I have requested a price from them.
As mentioned I visited WR Long's site that Maps and others mentioned. I have not called their place in Tarboro NC. I have requested a price for the Long open bottom grapple and the Kubota 3rd function valve kit via the dealer where I bought my tractor. According to dealer the Kubota valve kit could run a hydraulic motor if I ever had the need. The Long site indicates their diverter is not sized to run a hydraulic motor. Not sure yet I'll use this type of hydraulic control.
Firefighter I enjoyed viewing your install thread for the add on grapple, great job! I gotta learn to weld :eek:
Farmboy I did search for Versatech and found it on Ebay. I was beginning to wonder if all grapples were made here in NC! :p The price is a little over what is posted by Unlimited Fab. which I could pick up and save shipping.
Island Tractor and Pitt Md I appreciate the input on the rear hydraulics as the mechanism to control the grapple and other uses. This is something else to consider. I will also have to investigate how the rear remote controls could be installed on my tractor to allow the grapple control to be near the loader control. I understand the input on size of grapple. For the open bottom, versus clam shell grapple Unlimited Fab. only has a 63" width as smallest they offer, not sure of weight. Markham痴 smallest is 60 and 770lbs. WR Long痴 48 is 350 lbs, the 56 460 lbs., 64 490 lbs.
All
Thanks for the continued feedback and input it does help me to form opinions and narrow search. Based on your input and discussion I am leaning toward the grapple with the open bottom versus the clam shell or add on grapple. Not sure yet on size or brand, that could be driven by price. Nor have I determined the best approach to plumb the hydraulics.
   / Grappling for answers on Grapples #19
I have a WR Long RBG2-60 grapple for use on a Kubota L4310. Not a lot of use, but it's very handy for moving small boulders ~ limit 1,200 lb. Brush gathering is good, log loading - less so.
I expected the holding power to be greater, but the upper arm doesn't have a lot of holding power - could be redesigned, IMO. I also looked at an ANBO, but couldn't justify the price extra.
   / Grappling for answers on Grapples #20
Our hydraulics are a beast to hook up on our '05 M4900. Don't know if it is different on L's. With the QA up front, you'd expect things to be quick and easy. Not so with the Hydraulics..
Are you having trouble releasing pressure before hooking up the quick connects? I cannot understand how it could be difficult to hook up the hydraulics otherwise.
There are some special QC fittings made that permit automatic release of residual pressure, I think Pionner sells some like that. I just make sure that I release pressure in the system before I try to hook up hydraulics on the FEL and if there is still resistance I just "gently" whack the spring loaded tips to release the pressure.
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
