Grapple
   / Grapple #1
3238dpw
Central NJ
Power Trac 425, C-121 Wheel Horse, 2 Exmark 60 inch zero turn mowers
   / Grapple #2
   / Grapple #3
It weighs 300 pounds and sits at least a foot in front of your quick attach plate. You'd be lucky to lift 400 with it.
   / Grapple #4
Adjustable forks would be nice; like you I find the PT forks too narrow a lot of times.
But since those forks weigh 200# more than my forks, that is a non-starter. I pick up stuff at or beyond my capacity all the time, and I wouldn't give up an additional 200# of lift capability.
   / Grapple
I totally agree about the weight. I already have the or forks but was thinking about these also. Then I would have the or forks for heavy loads and the Titan forks for wide loads
   / Grapple #6
You're also going to have to add/subtract some mounting material and a quick attach. That may add or subtract weight as well. As long as you are aware.
I know if I use my large bucket I can fill it with patio blocks and tip on my nose fairly easily. I also have picked up some huge logs (for a 1500 pound machine) with the PT forks and tip on nose from time to time. I wouldn't want to add too much weight out away from the quick attach plate if at all possible.
Anyone know what the PT grapple bucket or utility grapple weigh?
   / Grapple #7
Don't know the exact weight, but I'd guess the Class 8 grapple bucket to weigh about 100 lbs. I can wrestle it around fairly readily when unmounted.
   / Grapple #8
The Power -Trac 29" T3424 Utility Grapple seems to be a better solution for your PT-425. $800
NEW
Scroll down to see it
   / Grapple #9
I keep looking at that factory utility grapple and I'm convinced I could bend it with abuse. I bent the forks with abuse, rather easily, too. Using them to pry stumps out of the ground.
I like the looks of their grapple bucket, though.
   / Grapple #10
I used mine a lot since 2010. It's heavy iron - not easily bent. I have never bent it. I recently move a tree that had fallen across my road -probably 500 lbs.
2019 John Deere XUV560E Utility Cart (A53421)
2019 John Deere...
2018 CHEVROLET SONIC (A55745)
2018 CHEVROLET...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55302)
2019 Krause...
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
2010 Cadillac SRX SUV (A55758)
2010 Cadillac SRX...
UNUSED Wheeled Dump Hopper (A47477)
UNUSED Wheeled...
