Grapple Switch
   / Grapple Switch #11
That's bleeping ridiculous. You could call Fasse and see what they will do for you. Here is a pic of mine that I got from them:
I found the switch:
K1008 Normally Open Internal Lever Switch | Control Products Inc
Call those guys and get one direct or from a distributor. $120 is just silly.
   / Grapple Switch #12
There are literally hundreds of switches you could use for your grapple. Try looking at Digikey or Mouser. Sometimes I also find good deals at allelectronics
   / Grapple Switch
I looked better at my joystick lever handle this weekend and it has a removable rectangular plate where the factory switch (Nimco) is to be installed. Porblem solved remove platedrill hole install any SPST 6A or better switch in hole reinstall plate. Well nothing is ever that simple but on paper it works real good!:drink:
I know that I can buy switch and wire for way less anywhere, and the valve has weatherproof boots that I can buy when I get it it. Since my joystick is on the tractor and not on the loader I bought this plug on ebay the other day
Panel Mount Connector 20 Amps 12VDC 12 Gauge Wire | eBay
so I could unplug the wiring to the valve when I disconnect the 4 hydraulic hoses to remove the loader. I am also going to install a lighted power switch in the dash so I can turn off all of the power to the diverter valve when I have the bucket on and/or when I remove the loader. Switches SPST and lighted are a dime a dozen (so to speak) any where auto parts store, wallyworld, hardware stores I like ebay less driving better selection and in most cases shipping is free, but if you need it tomorrow then ebay is out. Ok I think I have found everything I need all I have to do is part with the money!:thumbsup:
   / Grapple Switch #14
I got a response from Fasse. Switch is McMaster-Carr Part # 6944K132 $44.87 in their catalogue.
   / Grapple Switch #15
I tried to run that number and got this response from McMaster-Carr
No matches were found for "6944K132."
   / Grapple Switch #16
Get rid of the 2 on the end. That is the one I have.
   / Grapple Switch #17
Here's the gadget I got in the mail today to monitor house loads. This panel shown has no wires connected to it. a couple of clamp on transmitters connect to the 2 mains coming into the house and transmit the readings to the panel shown. 4 clamp on's are furnished so two can be used on the gen set as well.
From what I understand this will keep track of 2 years worth of data.
   / Grapple Switch #19
Absolutely. The only issue I have with any part of my 3rd function/grapple system is the problem relieving pressure to allow reconnect. ...Well documented in these forums... The switch is very solid.
   / Grapple Switch #20
I have found it easier if engine is stopped, turn key to on position, engage grapple switch, work joystick both ways to relieve internal pressures.
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2021 Liebherr L556 (A51039)
2021 Liebherr L556...
2014 STONE RIDGE 38FL 5TH WHEEL CAMPER (A50854)
2014 STONE RIDGE...
2018 HINO 258 SERVICE TRUCK (A51243)
2018 HINO 258...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump with Hose Reel (A49461)
2025 LandHonor...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
