Grapple grapple rakes/buckets
/ grapple rakes/buckets #1
farmerpsv
VA
NH TN65
am buying a piece of land thats been cut over, there's lots of branches, cut trees. would appreciate any info on cleaning such debris with a grapple. i've seen that there are a few different kinds. one looks like a bucket with a clamp, probably not good for my purposes. one looks like a fork lift with a clamp, which is kind of cool because it looks like it would hold alot, get under stuff fairly easily and you'd have a forklift as well. then there's the one that is a 'rake' (i think) and that looks like it would could work well going after roots as well as branches? any help, experience or sage advice would be appreciated.
thanks,
paul
/ grapple rakes/buckets #2
I use a Worksaver skid steer grapple on both my 2120 and TN and it works great for the type of work you describe. Cost was about $2300 Worksaver Grapple
Andy
/ grapple rakes/buckets #3
Check out: www.anbomanufacturing.com
Request their full brochure and video on their Grapple Rakes. Give Terry Anderson (the president) a call and ask him any questions.
They make a first class product that are idealy suited to your application.
Rip
/ grapple rakes/buckets #4
I have the PIRANHA ROOT GRAPPLE costs $1450...has worked well for me...
GareyD
Thanks everyone for your info and replies. am i correct in thinking the rake will tackle roots as well?
paul
/ grapple rakes/buckets #6
The lower tines on the AnBo rake are about 5 to 6 inches apart and will "rake" the ground well.
If you need to get under a single root or two with a single long narrow fork, then this style will not be the best unless you can catch the roots with a corner of the rake (it is certainly strong enough).
Rip
/ grapple rakes/buckets #7
For what it's worth Paul I have a similar situation. After looking at the cost of grapple buckets I decided to go rough on it. I just took this pile of brush and rolled it like a dead mouse, squished it with the loader bottom, rolled it some more then rolled it over two chains I have and tied the whole mess together. Carried it several hundred yards and only lost a little. I'd guess there were four hundred pounds at least since the bucket is filled with some large, wet hardwood about 14" in diameter.
/ grapple rakes/buckets #8
I got a 4310 week B4 last and yesterday my dealer brought out my "Bodozer Grapple." I think it's the same as the AnboManufacturing grapple rake, just Deere Green. It's the 60" one. They have smaller and larger. If you can, get one. I spent one really satisfying day today on the 4310 messing with that grapple rake. It is NICE! I got it down. If it weren't for the "woulda shoulda" syndrome I'd have pics, but I was having too much fun. I yarded out a couple of 20" butt by 40' or so fir then picked them up and "placed" them where I wanted them. It moves the root wads around just as well. This didn't phase the hydralics - it's capable of bigger stuff but that wouldn't seem practicle for a day job as with this small a tractor you are well aware you've got something serious gripped by the grapple. It will rake and pick up one hunk of brush. I put a burn pile together today the size of a 2 car garage - well, 2 real little cars. It'll pull up relatively small root clusters pretty good but there needs to be enough to get a bite on. I was burying the rake into the ground under them then curling it to lift. These things are really slick.
Joel
/ grapple rakes/buckets #9
Hey guys, first post, another city guy with a life long dream of moving to the country. My wife and I bought 17 acres of hills and rocks covered with Oak in Montague county TX that has a lot of dead fall. I've decided a grapple rake is the tool I need, just haven't pinned down the machine to put it on. I've considered an ASV RC 30 and a 4WD tractor. I'm dealing with rugged terrain and dense woods, so maneuverability is a consideration. I've done some searching here and appreciate the info in this thread and on this site. Thanks, looking forward to getting to know you and hearing your ideas. Mike
/ grapple rakes/buckets #10
I have a rock bucket with grapple that I use on my Cat257 I purchased it from Attachment Express While the Rock bucket is build solid The plumbing on the grapple is poor I have gone thru 2 sets of hoses due to binding.It looks like I will have to redirect the hyd. lines. to keep them out of harms way.
Joel,
sounds pretty cool to me. do you mind me asking what you paid for the grapple?
paul
/ grapple rakes/buckets #12
Paul
$2850 - It might be $2650 through Anbo Mfg.
Joel
/ grapple rakes/buckets #13
RedRocker,
After much deliberation I bought a Power Trac PT-1845 45hp diesel fully hydraulic articulated 4x4 (see Power Trac forum and www.power-trac.com web site) plus an AnBo 5'GRL Grapple Rake as the most agile and versitile combination I could come up with.
I already have a New Holland TC-30 CUT, but it and any others of similar style are simply not stable enough for steep rough hill sides like we have at 8000 ft in the Rockys. My application is removing dead fall and cut trees and slash for wildfire mitigation with minimal land impact.
Give this or similar combination serious consideration as you look around at various alternatives.
Rip
/ grapple rakes/buckets #14
Thanks Rip, I'll look that deal over.
/ grapple rakes/buckets #15
I have one of the worksaver grapples mounted on my Kubota M6800. Works great for all kinds of debris...have to remember to use my counterbalance on the rear with it for the heavier stuff.
ED
JOHN DEERE 7210 TRACTOR (A60430)
JOHN DEERE 7210...
John Deere 6300 (A60462)
John Deere 6300...
EXCAVATOR JACKHAMMER (A58214)
EXCAVATOR...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
UNUSED MINI EXCAVATOR QUICK COUPLER (A60432)
UNUSED MINI...
UNUSED FUTURE MB27-27" HYD MIXING BUCKET (A60432)
UNUSED FUTURE...
