grapple hydraulic setup 1026r
   / grapple hydraulic setup 1026r
I built it out of scrap metal
3/8 x 4 x 4" angle
1/4 x 1.5 x 24" flat bar
1/8 x 3 x 96" tubing
1/4" mounting and lifting points
1/4" chain to bucket
All welded with 7018
It can safely hold 800-1000 lbs at the lowest lug and 250 at the top lug
   / grapple hydraulic setup 1026r #103
Thanks for sharing and again live that grapple.
200 lbs of steel rigged at 9.5 ft from bucket pivot with the boom at a 45 degree angle. This is equivalent to 950 lbs at the pivot.
At this height I could not lift, only curl.
Here's me as the counterweight. The rear end was very light
   / grapple hydraulic setup 1026r #107
Ok from the picture it looked like a lot more weight.
I know. I had a case 580 fill my pickup bed in two half scoops and my tractor took about 8 full buckets to unload it :-(
   / grapple hydraulic setup 1026r #109
Swick1 I'm looking to adapt a power angle snow plow onto my 2320 with 200CX loader. This Solenoid looks like the way to go to get hydraulics diverted to the power angle cylinder. Is it a 2 way pressure valve? If so I could just divert the bucket curl/dump fluid when needed to change the angle of the blade. That would work great. Or any other advice you may have.
I had the Jd dealer cut the curl hose after I mounted the valve to the loader. They put new ends on it where they cut and hooked it up for me. I installed the two remote hoses myself. I made them out of repair fittings from discount hydraulics.com. they are frontier style disconnects but I would do flat face next time. Jd dealer had the covers for the hydraulic quick disconnects. I installed a foot pedal to switch between controlling bucket curl and the grapple. It works well but I had to make my own bracket to hold the switch. I love my diverter setup. I want to make some more implements that use the hydraulics like a stump puller and a shear / jaw crusher.
POWER CORD W/ REEL, 12G WIRE, VICE (A51244)
POWER CORD W/...
2011 Cadillac SRX Luxury SUV (A50324)
2011 Cadillac SRX...
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
Friesen 220 Seed Tender (A50514)
Friesen 220 Seed...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2015 CATERPILLAR 299D SKID STEER (A51242)
2015 CATERPILLAR...
