Grapple compairson
/ Grapple compairson #1
p50
Ms
none
Looking to purchase root grapple for John Deere 4044 m tractor.Width & weight suggestions.Which is better grapple LMC or Wicked
/ Grapple compairson #2
Some explanation of what you want to do with it would make for better suggestions.
Will be used to clear wooded area.No to rocks or boulders
/ Grapple compairson #4
never used either, however i have used others and i can tell you i DO NOT like the design of the wicked, why, because another manufacturer with the same design, ( neighbor has one ) i have used several times on my skid steer those fittings all in the center will get broken/damaged/leak, when you oscillate up/down you are putting those fittings in a spot for trouble, also if something comes thru the center of the grapple arms you are screwed before you know it, ask me how i know it looks like the lmc has put theirs in a more protected position and less apt to get damaged - i would definitely be welding something over them to protect them that could be removed with bolts like they put over the cylinders/fittings - just my .02
/ Grapple compairson #5
The Wicked grapple has extra bars welded across the back to keep larger stuff from protruding towards the tractor. They use swivels in the hydraulic connectors between the two cylinders so the hoses aren't being twisted. Small things that you'd see if you were looking at an actual Wicked grapple and not someone else's grapple. I've not had a problem with material grabbing the hoses.
/ Grapple compairson #6
i have used a grapple like the wicked with the swivels on the hoses and no thanks, i havent had problems with hoses getting in the way or the grabbing of the hoses, the debris falls thru and or pokes thru and breaks the fittings due to the placement of the fittings and no cover, then you rotate the bucket out/down to grab items and pick them up like a claw, the fittings are exposed and get busted
it doesnt matter what the name is im not picking on wicked i just saying its a piss poor place to put them w/out a cover
its an easy remedy with a cover plate welded or added that is removable, i swear the engineers that make things sometime dont ever get off their chair and go out and sit in a skid steer and work with the attachment or pick up anything or drive into a pile or dig a hole etc........they look at it on CAD and say Wheeeeeeeeeeee dont that looooook purdy!!!!
/ Grapple compairson #8
Wow, what manufacturer uses their grapple more than Sir Ted, aka. lead Wicked Grapple engineer?
BTW, if anyone was wondering...thousands of grapples in the field and the hose fittings present no issues.
Travis
Yeah, he sorta uses them in multiple environments and puts it out there for the world to see...
Oh, we also kinda went out of our way to prove the durability of our hoses and fittings. ..
/ Grapple compairson #9
To answer the OP's question, our 400 pound, 60" Wicked Root Rake Grapple has been simply on fire for tractors like yours.
It is one Highly Functional Work of Art like nothing else on the market. The only thing you'll ever have to worry about is what to grab next!
Travis
The AR450 steel and DOM tubing combo we use is unmatched by anyone!
/ Grapple compairson #10
you sound like some sales rep advertising not wanting to buy something else or compare, bring one over here i can have those fittings snapped off in a new york minute or faster
/ Grapple compairson #11
Very nice to meet you. We'll stick to trusting Ted's grapple testing, but do appreciate the thoughtful offer.
I'm steps from the EA factory floor and have lived grapples on TBN and elsewhere for YEARS, but you can call me some sales rep if you'd like. :laughing:
Travis
/ Grapple compairson #12
greetings, so your point in comparing was?
KL480 Ventrac tiller
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A66738)
2021 Mercedes-Benz...
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2006 KENWORTH  CAB & CHASSIS (A67714)
2006 KENWORTH CAB...
2008 WINSTON AP22024AL-DC EQUIPMENT TRAILER (A66091)
2008 WINSTON...
