Grapple became unattached.
   / Grapple became unattached. #11
I wonder if you might need new tensioning springs on the latching levers. Mine are really quite hard to pull "open". My springs provide tremendous "closing" force.
   / Grapple became unattached. #12
I agree with Smokeydogs fix at the bottom.
This is the gap that he shimmed:
   / Grapple became unattached. #13
This is why Kubota QA has a problem with forks and grapples coming off if there is a gap at the bottom.
Compare Bobcat top of QA:
To Kubota top of QA:
frj777 you need to check the top of the QA plate on the grapple to see if it is bent out or still straight:
   / Grapple became unattached. #14
Adding to X-mans post you really need a close fit in the three places pointed to by the arrows in the pic. Make sure there is no gap between the face of the SSQA and grapple first. Then add shims as required to close any gaps at the bottom or/and pin.
gg
   / Grapple became unattached. #15
I've had the same problem with my Kubota QA and my grapple. For some reason the Kubota arms are easy to be pushed open by brush, etc. If I'm doing a lot with the grapple I ratchet strap them closed. I don't seem to have an issue with anything else than the grapple.
Hey Solitary Man,
What Grapple do you have?
   / Grapple became unattached. #17
There is another potential issue depending on the design of the top mount of your grapple and the Kubota SSQA plate. I dealt with this years ago. I shimmed the bottom, which was probably necessary in any case but the problem was not completely resolved until I added more back-up plate near the upper hooks to stop the hooks from being able to flex and pop out.
This thread covered it:
Appreciate these comments and pictures. I did not understand what was at play, now I do...wish I could weld.
Manufacture will be getting back to me soon.
   / Grapple became unattached. #19
As 4570Man said the quick and easy is to shim the top with some 1/4”-5/16” flat bar. Held in place with a couple of 1/4”bolts that don’t interfere with the tractor ssqa hitch. TSC or Lowe’s usually stock 4’ stuff. Weld or bottom shim an option. I like the bottom shim for more wedge pin strength but run larger equipment.
Welding is fun and always a good skill to have. One of the few hobbies I have that pays for itself. Vocational school evening class is a great way to learn hands-on to get started.
Be interesting what the manufacturer says. Sorry you are having troubles with a new attachment.
   / Grapple became unattached. #20
Sounds like the levers are out of adjustment, mine are not easy to disengage, check the spring load on both the levers pivot and the wedge spring. They will wear and become looser with age.
2017 CATERPILLAR 12M3 MOTORGRADER (A51246)
2017 CATERPILLAR...
2025 JMR Stump Bucket Skid Steer Attachment (A51691)
2025 JMR Stump...
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
UNUSED INDUSTRIAS AMERICA 10F HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
UNUSED HURRICANE G350 MINI CONCRETE MIXER (A51248)
UNUSED HURRICANE...
