Grand L Third Function Control On Joystick
   / Grand L Third Function Control On Joystick #1
Maddog10
Western KY
Massey 1742
I'm looking for a picture of how the 3rd function control integrates into the factory joystick for the loader on a Grand L tractor? I'm sure it's on the site but I can't seem to find it for the life of me.
I'm looking to purchase a Grand L with the factory installed third function and just curious to see what the loader controls look like afterward. Is it a toggle switch that you operate with your thumb? Is it mounted separately on the lever? Is it turned on/off or always active? Sorry for the newbie questions but, well, I'm a newbie. I've read all I can about it but I guess I'm just a visual type of guy. I think a picture would explain it all.
   / Grand L Third Function Control On Joystick #2
Depends up whether a ROPS or cab model.
SDT
   / Grand L Third Function Control On Joystick #4
I looked and I don't have picture of it, but in the cab model the joystick has a bunch out on top that allows the switch to be placed there. The power switch is mounted lower on the joystick stem that allows you to turn the power on/off to the 3rd function valve.
If I can remember, I will try to grab a picture the next time I'm out at the farm.
I would appreciate it. I did notice the punch out while sitting in one the other day and wondered if that was the purpose. Seems like an ideal setup for a simple and ergonomic use, which was my hope.
My whole reason for bringing this up is I visited the Kioti dealer yesterday and they had a nice ergonomic handle. When I mentioned 3rd function the salesman said that entire handle would be swapped out for one designed for 3rd function and I didn't know if that was the case for Kubota.
   / Grand L Third Function Control On Joystick #6
The use the handle that is there. I had the Kubato dealer install mine. The switch fits perfectly in the punch out.
   / Grand L Third Function Control On Joystick #7
Thank you motorboatin... And the power supply would just be mounted on the stem of the joystick I assume from BRMyers description? Are there any consequences if the power supply is left on and a third function button is pushed while there is not a third function attachment hooked up? For example, I accidentally leave power on and hit the button while I have the bucket on instead of grapple.
   / Grand L Third Function Control On Joystick #9
The power supply is hidden and you might only see a wire running down the into the boot. I can't remember if the wire hidden inside the arm or not. I don't have a Kubota but if I hit the button in my Massey with no attachment I hear the hydraulics sequel. The pump doesn't run unless you hit the thumb switch
I really like the third function buttons integrated into the joystick on my Massey and Kubota has a nice clean setup as well
   / Grand L Third Function Control On Joystick #10
Just for sake of comparison, I snapped a picture of the factory installed 3rd function on my ROPS L3560 since I went out to check something else....
Rocker on handle controls flow, button on the mounted block turns 3rd function capability on/off
2000 Nabors 40 Ton T/A Flatbed Equipment Trailer (A55973)
2000 Nabors 40 Ton...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
2009 Ford F-750 Forestry Chipper Dump Truck (A55973)
2009 Ford F-750...
2015 Chevrolet Express Box Truck, VIN # 1GB3G3CG3F1110762 (A57453)
2015 Chevrolet...
2015 Ford E-350 Cutaway Box Truck (A55973)
2015 Ford E-350...
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
