Grand L Third Function Control On Joystick
   / Grand L Third Function Control On Joystick #1
Maddog10
Member
Western KY
Massey 1742
I'm looking for a picture of how the 3rd function control integrates into the factory joystick for the loader on a Grand L tractor? I'm sure it's on the site but I can't seem to find it for the life of me.
I'm looking to purchase a Grand L with the factory installed third function and just curious to see what the loader controls look like afterward. Is it a toggle switch that you operate with your thumb? Is it mounted separately on the lever? Is it turned on/off or always active? Sorry for the newbie questions but, well, I'm a newbie. I've read all I can about it but I guess I'm just a visual type of guy. I think a picture would explain it all.
   / Grand L Third Function Control On Joystick #2
Depends up whether a ROPS or cab model.
SDT
   / Grand L Third Function Control On Joystick #4
I looked and I don't have picture of it, but in the cab model the joystick has a bunch out on top that allows the switch to be placed there. The power switch is mounted lower on the joystick stem that allows you to turn the power on/off to the 3rd function valve.
If I can remember, I will try to grab a picture the next time I'm out at the farm.
I would appreciate it. I did notice the punch out while sitting in one the other day and wondered if that was the purpose. Seems like an ideal setup for a simple and ergonomic use, which was my hope.
My whole reason for bringing this up is I visited the Kioti dealer yesterday and they had a nice ergonomic handle. When I mentioned 3rd function the salesman said that entire handle would be swapped out for one designed for 3rd function and I didn't know if that was the case for Kubota.
   / Grand L Third Function Control On Joystick #6
The use the handle that is there. I had the Kubato dealer install mine. The switch fits perfectly in the punch out.
   / Grand L Third Function Control On Joystick #7
Thank you motorboatin... And the power supply would just be mounted on the stem of the joystick I assume from BRMyers description? Are there any consequences if the power supply is left on and a third function button is pushed while there is not a third function attachment hooked up? For example, I accidentally leave power on and hit the button while I have the bucket on instead of grapple.
   / Grand L Third Function Control On Joystick #9
The power supply is hidden and you might only see a wire running down the into the boot. I can't remember if the wire hidden inside the arm or not. I don't have a Kubota but if I hit the button in my Massey with no attachment I hear the hydraulics sequel. The pump doesn't run unless you hit the thumb switch
I really like the third function buttons integrated into the joystick on my Massey and Kubota has a nice clean setup as well
   / Grand L Third Function Control On Joystick #10
Just for sake of comparison, I snapped a picture of the factory installed 3rd function on my ROPS L3560 since I went out to check something else....
Rocker on handle controls flow, button on the mounted block turns 3rd function capability on/off
NEW Fork Extensions (A59000)
NEW Fork...
FORD 3PT. REVERSABLE SCOOP PAN (A52708)
FORD 3PT...
2020 CATERPILLAR 306 CR EXCAVATOR (A52709)
2020 CATERPILLAR...
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
