Grade 8 Shear Bolt?
/ Grade 8 Shear Bolt? #11
Leaving this here. May help future readers.
Thanks for posting that little chart. I have seen similar when I looked for fastener strength comparisons between Metric and SAE but never bothered to save what I found. I even have a few editions of Machinery's Handbook, the earliest from 1918 and the newest from 2015 and the newest edition has the info. But now, thanks to you, I have it on my computer desktop also and this will certainly save time.
Cheers,
Eric
/ Grade 8 Shear Bolt? #12
Thanks for the replies!
Can anybody tell me the size of the bolt that I need?
8.8 mm in diameter. It's a metric bolt. As far as length, does your manual specify a length? You'll need an 8.8 mm nut(s) also.
/ Grade 8 Shear Bolt? #14
8.8 is a grade of bolt... 120,000 PSI shear not a diameter.... Metric bolts are generally even numbers as 6mm, 8mm, 10mm, 12mm and so on....
/ Grade 8 Shear Bolt? #15
I think there is some confusion here. 8.8 is the grade nothing to do with diameter, per se. Metric shear bolt size will be something like M10x50 “property class” 8.8.
This is the info to persuse. It probably going to be m8 or m10 by 1.0 or 1.25 thread pitch. Then figure out the length. 20mm, 30mm. Etc.
Stores will sell them denoted as M10x1.0x20.
/ Grade 8 Shear Bolt? #16
Did you ever figure out the bolt size?
/ Grade 8 Shear Bolt? #17
What is the diameter of the hole it goes in?
2000 REITNOUER ALUMINUM FLATBED TRAILER (A60736)
2000 REITNOUER...
2014 BRENNER TANK CRUDE TRAILER (A60736)
2014 BRENNER TANK...
2007 JLG 1930ES ELECTRIC SCISSOR LIFT (A59823)
2007 JLG 1930ES...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
