Grade 8 Shear Bolt?
/ Grade 8 Shear Bolt? #1
madtowneast
Member
Massey Ferguson 4707
Hi All,
I broke a bolt on my Case IH BS174R, specifically part # BER657199. The description is Bolt - Grade 8.8 Shear, & Nut. Is there such a thing as Grade 8 shear bolts?
Does anybody know what size the bolt is? The parts diagram says 6 are needed and I can’t figure where the other 5 are.
Thanks!
/ Grade 8 Shear Bolt? #4
Leaving this here. May help future readers.
Thanks for the replies!
Can anybody tell me the size of the bolt that I need?
/ Grade 8 Shear Bolt? #8
It might be easiest just to order the parts kit, unless you have a Case dealer near you. You probably will have it next week.
Better yet, order two; that way you can use one, and match the other up at your leisure.
/ Grade 8 Shear Bolt? #10
As point of reference:
6 mm is a little smaller than 1/4 inch
8 mm very close to 5/16 inch
10 mm is a little larger than 3/8 inch
12 mm is a little smaller than 1/2 inch
/ Grade 8 Shear Bolt? #11
Thanks for posting that little chart. I have seen similar when I looked for fastener strength comparisons between Metric and SAE but never bothered to save what I found. I even have a few editions of Machinery's Handbook, the earliest from 1918 and the newest from 2015 and the newest edition has the info. But now, thanks to you, I have it on my computer desktop also and this will certainly save time.
Cheers,
Eric
/ Grade 8 Shear Bolt? #12
8.8 mm in diameter. It's a metric bolt. As far as length, does your manual specify a length? You'll need an 8.8 mm nut(s) also.
/ Grade 8 Shear Bolt? #14
8.8 is a grade of bolt... 120,000 PSI shear not a diameter.... Metric bolts are generally even numbers as 6mm, 8mm, 10mm, 12mm and so on....
/ Grade 8 Shear Bolt? #15
I think there is some confusion here. 8.8 is the grade nothing to do with diameter, per se. Metric shear bolt size will be something like M10x50 “property class” 8.8.
This is the info to persuse. It probably going to be m8 or m10 by 1.0 or 1.25 thread pitch. Then figure out the length. 20mm, 30mm. Etc.
Stores will sell them denoted as M10x1.0x20.
/ Grade 8 Shear Bolt? #16
Did you ever figure out the bolt size?
/ Grade 8 Shear Bolt? #17
What is the diameter of the hole it goes in?
7ft Metal Gulf Gas Pump (A65583)
7ft Metal Gulf Gas...
2022 EZ-GO ELITE...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2009 INTERNATIONAL WORKSTAR BUCKET TRUCK (A63276)
2009 INTERNATIONAL...
2015 International WorkStar 7500 T/A Forestry Grapple Truck (A64556)
2015 International...
Keota MFG Bale Mover (A65640)
Keota MFG Bale...
